First post, by Sphere478
Post any benchmarks you like, but lets try to at least get 3dm 99/2k if you can.
Post your full system config including model numbers/versions of parts if you
can, OS, hardware, driver versions, hacks, tweaks, anything special.
Let the competition begin!
Sphere's PCB projects.
Reply 2 of 15, by BitWrangler
Not sure if there is one to find in the pile or not. Had a brief mention of an MP6 200mhz in some old scribbles, but it was in context of somebody else's machine I was fixing/upgrading, so not sure if I booped them up to k6-2-400 and dropped it in a box of junk or what. What I am a little surer about is I got an eBay lot of 6 new K6-2 400s, and swapped 4 of them into fam/friends machines early-mid noughts, ending up with two cyrix, one K6-233 and the fourth is in question. I have been able to reconcile about 90% of my ancient scribbles so far, the rest IDK if they will get explained eventually or not.
Reply 4 of 15, by debs3759
When comparing CPU benchmarks, it's probably best to use a CPU benchmark, rather than a GPU benchmark with no specific GPU 😀
Reply 5 of 15, by Sphere478
debs3759 wrote on 2022-09-25, 18:00:
In the aiming for the stars threads we have been usually doing quake and 3dmark stuff.
You can post whatever you like though super pi? Prime? Sandra? Cpu-z mark
Reply 7 of 15, by Sphere478
I have two. 😀
Need a few more of the models for my collection though. Would like to track down a 366
Reply 10 of 15, by Sphere478
pentiumspeed wrote on 2022-11-12, 00:04:
Compared to what other processors?
We compare to other rise builds 😀
Reply 12 of 15, by jasa1063
I just put together a system with a Rise iDragon (MP6) PR266 @200MHz. I am using a PC Chips M585LMR motherboard. Not a top of the line motherboard, but I got it cheap and it has the very handy CPU Plug-n-Play in the BIOS setup. It makes trying out different speed combinations much easier. Anyway here are the results I got using Speedsys 4.78
    54.35 KiB
    Speedsys 4.78 results
Reply 13 of 15, by Sphere478
Rise cpu voltage and multiplier settings
Reply 14 of 15, by jasa1063
I overclocked my iDragon to 250MHz with a 2.5x multiplier and so far it's been stable. I am also attaching the datasheets for the Rise MP6 & iDragon CPUs and Speedsys 4.78 results to compare to my previous post.
    54.21 KiB
    Rise MP6 Product Brief.pdf
    601.93 KiB
    44 downloads
    Rise MP6 Datasheet.pdf
    1.04 MiB
    40 downloads
    Rise MP6 Datasheet
    Rise iDragon Datasheet.pdf
    1.36 MiB
    48 downloads
Reply 15 of 15, by Sphere478
Got some new additions to the collection today :p IDK if I will bother testing them though unless someone thinks they may hold some secrets or performance I wasn’t able to see on the socketed cpus in the pic (the ones I already had)
Did ES cpus have any extra features or quirks?
    1000.16 KiB
