First post, by Guest
posting this again. some turd moved it to some other section that needs a user so I cant continue it there...
!!!Im nog getting sound stuttering just whit Golden axe, i get it with all applications runned under dosbox!!!
Hello!
I need help. have installed dosbox from a slackware pakage ( couldnt install from source, some illegal convertion from integer to struct ).
I now get a game starting but I cant get the sound from stop stuttering! Tried to change CPU cycles and core, been messing with the soundbuffering to but it just wont work!
The game im trying whit is Golden Axe. tried other games too.
Ive got a amd athlon 1800+ and 368MB ram.
what am i supposed to do now? what could be wrong?
cores tried: simle, normal and dynamic
Tried Ctrl +F11&F12 to get correct CPU cycles
tried making a bigger buffer and setting the prebuffer higher (10, 20,30ms)
have also tried running X in 16bbs but nothing works.
Whats wrong? and why cant i compile dosbox from source? i got all sdl-librarys. anyone? please?!
Reply 1 of 6, by eL_PuSHeR
I was "that turd". Why not registering?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by Snover
What 'other games' have you tried?
Yes, it’s my fault.
Reply 4 of 6, by Guest
Dune, Dune 2, pinball dreams, pinball fantasy, pinball illusions and turrican II.
same stuttering in all games.
Reply 6 of 6, by Guest
make[3]: Entering directory `/home/tobbe/spel/dosbox/dosbox/src/gui'
if g++ -DHAVE_CONFIG_H -I. -I. -I../.. -I../../include -I/usr/local/include/SDL -D_REENTRANT -g -O2 -MT sdlmain.o -MD -MP -MF ".deps/sdlmain.Tpo" -c -o sdlmain.o sdlmain.cpp; \
then mv -f ".deps/sdlmain.Tpo" ".deps/sdlmain.Po"; else rm -f ".deps/sdlmain.Tpo"; exit 1; fi
sdlmain.cpp: In function `GFX_Modes GFX_SetSize(unsigned int, unsigned int,
unsigned int, double, double, void (*)())':
sdlmain.cpp:480: error: invalid conversion from `int' to `GLenum'
sdlmain.cpp: In function `void GFX_EndUpdate()':
sdlmain.cpp:637: error: invalid conversion from `int' to `GLenum'
make[3]: *** [sdlmain.o] Error 1
This is my error message. Do I have wrong version of sdl? It sure doesnt look like a dependencies problem.
Anoying to get programming errors when trying to compile something like this.. 🙁
