ram upgrade
First post, by kenan83
Hello. I have 1 PCI s3 video card and a cirrius logic gd5428 vlb video card. I want to install two ram from S3 to the empty sockets of cirrius. But I couldn't understand how many ns the rams on S3 are. I looked in the datasheet and couldn't find it. Are these rams suitable for cirrius as ns. I would appreciate if you could help.
Reply 1 of 6, by Grzyb
V53C16258H is EDO.
Your GD5428 most likely needs FPM.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 6, by waterbeesje
Most probably not, they are different architecture. EDO is newer and faster. I'd the specific chip has the ability to run in FP mode it might work, but for that you'll have to look into the datasheet.
Stuck at 10MHz...
Reply 4 of 6, by kixs
Just swap the two chips and you will see if it works. Usually it doesn't. But it won't break anything if it doesn't. Also you won't gain much with 2MB of memory. For DOS 1MB is enough and this card is pretty basic as a Windows accelerator.
Reply 5 of 6, by Grzyb
kixs wrote on 2022-09-29, 23:27:
True.
The only additional modes are 1024x768x16bpp and 1280x1024x8bpp - both interlaced, so pretty much useless.
Reply 6 of 6, by kenan83
Hello. I would like to share my experiences. I placed the memories I bought from S3 into the empty memory slots of cirrius. In my tests, the system saw the card as 2 mb. I didn't get any error sounds. The card works normally. However, the display is distorted during window transitions in windows. When the screen is refreshed, it returns to normal. There is no problem in normal use with DOS. I don't get color depth in games either (Doom). As far as I understand, edo and fpm rams work incompatible together. Now I will have to find fpm ram to cirrus.🙂
