First post, by digicube
Curious if it's possible or is it encrypted?
Reply 1 of 2, by BitWrangler
Sounds plausible if you've got the cartridge to disassemble.. https://obsoletemedia.org/govault/
Reply 2 of 2, by DAVE86
digicube wrote on 2022-10-05, 23:39:
Keep in mind that the controller does use custom encryption and checks the drive ID too . At least it is the case with the SSD versions. If you swap it with a different drive it might not function.
