Reply 20 of 21, by mkarcher
damjank wrote on 2022-10-11, 07:34:
So overclocking, also for DOS, comes to play with DX cards then?
If a DX card runs at a DX-worthy clock (i.e. around 70MHz), it is fast enough for all DOS stuff, so no overclocking required. If you get a card wit a BIOS that initializes the clock at 45MHz, run a MCLK change tool from autoexec.bat to improve the clock. Going to 80 or 90 is irrelevant unless you need 3D performance.
Reply 21 of 21, by damjank
mkarcher wrote on 2022-10-11, 15:52:
Thanks for this info!
