First post, by Tronix
I recently partially ported libFLAC to 16-bit open watcom compiler. Don't ask me why -)
So, there:
FLAC2WAV <input.FLAC> <output.WAV>
Minimal system spec: 8088 XT 512Kb RAM. Two versions in archive - for XT and 286/NEC_V20 computers. The presence or absence of a 80x87 coprocessor does not affect the speed.
WAV2FLAC <input.WAV> <output.FLAC> [N]
where N is compression level. Default compression is 5.
Minimal system spec: 80286 with 2Mb RAM. The encoder requires significantly more memory for internal structures and buffers than the decoder, so I had to switch to protected mode using an Phar Lap's 286 DOS extender. Mathematics with float numbers is intensively used for encoding, so the presence of a 80287 coprocessor significantly affects the speed. Three versions in archive - 80287 FPU, integer only math (FLAC__INTEGER_ONLY_LIBRARY define) and without FPU (emulation, very slow) .
Just for lulz, nothing more.
    WAV2FLAC.ZIP
    738.13 KiB
    58 downloads
    FLAC2WAV.zip
    173.21 KiB
    69 downloads
https://github.com/Tronix286/
Reply 2 of 4, by Grzyb
I'm wondering how long it takes to decode 1 minute of FLAC sound on an 8088@4.77...
...but no, I don't want spoilers, some day I'm going to revamp my Turbo XT, set it to de-turbo, and see for myself 🤣
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 3 of 4, by Gustavo
Grzyb wrote on 2022-10-11, 02:01:
I´m curious too. I bet it will be more than an hour, but sometimes the little Intel surprises me.
Reply 4 of 4, by Tronix
And now MP3 to WAV simple decoder for [XT][8088].
I used Helix mp3 decoder from RealNetworks. I made changes to the assembly.h file (rewrite MULSHIFT32(), MADD64(), SAR64() in 8088 assembler). Source code: https://github.com/Tronix286/HELIXMP3
So, actual version here: https://github.com/Tronix286/HELIXMP3/blob/main/real/mp3.exe
MP3 <input.MP3> <output.WAV>
