First post, by nfraser01
HI All
I've sucessfully removed the BIOS password from an old Toshiba before (Parallel port hack) but I've recently acquired a Z-Note 325L which came with a BIOS password. I've tried a few obvious passwords but does anyone know of any password bypass techniques instead?
Googling seems to suggest shorting 2 motherboard pins might work but I don't have specifics for this particular motherboard ...Anyone know where to start looking?
TIA
PS I *like* this forum font...
Reply 1 of 14, by Horun
Yeah wish I could help but the only "vintage" laptop I have left is a Toshiba Satellite 110cs. Decades ago had many but they became too much work if there was an issue so sold most. Now wish I didn't....
I know there is a great collector market for them but for me back then the work you have to do to fix one was near obscene compared to a regular vintage PC 🙁
Reply 2 of 14, by BitWrangler
I used one for many years, but never locked myself out. What type of password is set, boot password or just can't change settings?
Either of these work? https://www.passwordsdatabase.com/vendor/zenith
If you only have settings lock, you can maybe get rid of it with a CMOS clear util, if you have the floppy and booting floppy is enabled.
Though there's an itch in my brain about this being the system I had when I first learned about HDD locked passwords. So wondering if the manual said something about it, or whether it was in relation to something else.
Reply 3 of 14, by nfraser01
BitWrangler wrote on 2022-10-16, 04:47:
Appears immediately on boot so BIOS/Boot password. I've removed the hard drive and still appears so definately not a HDD password.
Not seen this list before - thanks. Will try the 1st one. Already tried the second...
Tried CMOS battery out for 24 hours but no help...
Thanks for the input. I'll keep everyone updated
Reply 4 of 14, by nfraser01
nfraser01 wrote on 2022-10-16, 10:45:
Nope, no luck.
Looks like its going to have to be a motherboard short circuit. Just need to find out what needs shorting to what 😒
Reply 6 of 14, by nfraser01
Predator99 wrote on 2022-10-16, 21:01:
Is the EPROM on a socket and are you able to replace it? Can you provide a dump of your BIOS?
Can't recall from wghen I had it apart. will look when I get the chance. I don't have any EPROM readers etc though...
Reply 7 of 14, by BitWrangler
Since battery removal and clear attempts have you tried to enter a null string password? (just press return) because some clear and still have the prompt.
Reply 8 of 14, by nfraser01
BitWrangler wrote on 2022-10-16, 21:58:
No, I probably have not....
Reply 9 of 14, by esasoft
nfraser01 wrote on 2022-10-16, 20:29:
Nope, no luck.
Official Zenith Data Systems BIOS "Password Removal Menu" guide (downloaded from WA copy of Packard Bell old FTP).
PASSWORD.zip
37.94 KiB
36 downloads
"Z-Note 320/325
Remove maths Co-Pro Cover above Kbd on top of machine.
to left of co-pro socket are a pair of solder pads R39.
Power off the PC ( Set to OFF/ON not Rest/Resume )
Short the PADS and power up the PC. Wait until all the ICONs on the LCD panel blink. Remove the short, then do a hard/cold reset ( press Power and Reset buttons ).
This procedure also deletes the LAN ID. Use SETLANID to re-enter the LAN ID."
Reply 10 of 14, by nfraser01
esasoft wrote on 2023-11-27, 13:04:
Amazing bit of info.
I can see the silkscreened R39 but I can't quite work out which pads it refers too - I'll have alook again in better light.
Fingers crossed it will work
Thanks again
Reply 12 of 14, by nfraser01
esasoft wrote on 2023-11-29, 06:56:
Well, did it help?
YES!
I was able to start the machine for the first time.
It appears the hard drive is faulty as it won't spin up. Interestingly the laptop didn't even try to do that with the password in place.
Also intestingly it's dumped me into some kind of monitor programme that allows testing, reading am executing memory addresses and other interesting stuff... See attached picture
Thanks again.
Reply 13 of 14, by vetz
It's a little offtopic for this model, but I'm not sure this information is on the web. For Zenith models:
- 286 LP/8
- 286 LP/12
- 286 LP Plus
- 248/12
- 386SX
- 386/20/25/33
- 386/33E
- MinisPort
- MinisPort HD
The password can be disabled by removing the EEPROM chip from the board or grounding pin 4 on the 93C46 EEPROM.
343.54 KiB
Reply 14 of 14, by bjwil1991
Where can I find the SETLANID command? The original HDD I have in my Zenith is totally dead and I don't have recovery media for it.
