Sad Voodoo 3
First post, by quicknick
Got this Voodoo 3 from today's flea market, but when I got home it turned out that the green spots that looked like corrosion were really corrosion 😐
They even reacted (bubbled) when I bathed the card in vinegar, so who knows, maybe the card was stored together with some leaky 286 boards or whatever. Here's how the most damaged part looks like, after scraping most of the green gunk and lightly sanding the 'fingers' :
1.83 MiB
I'd say it's pretty bad, gaps on at least two traces (Vddq 3.3, AD17) and a few more that definitely need reinforcing. Soldering on/near AGP fingers gives me the shivers, and I can almost envisage all their surface engulfed in solder...
There's also some corrosion between the top RAM chips and on a couple of vias near the vBIOS, but these areas don't look nearly as bad as the one near the AGP connector. I'll leave here a few more photos:
https://imgur.com/a/ZIx6wEo
So, any ideas on how I should tackle this? Bin the card, pray to the Voodoo gods, try to bridge the gaps with very fine strands of copper wire? Is kapton tape suitable for keeping the solder from 'wetting' the entire golden finger when soldering on it?
Reply 1 of 6, by Sphere478
Tin them. The broken traces may be tricky. Being that that area inserts into the slot. Use very small wire.
Sphere's PCB projects.
Reply 2 of 6, by pentiumspeed
The proper fix is find an scarifical AGP card with same contact finger design, nick and cut tracks, peel off damaged contacts, same time do same to salvage AGP card, cut longer track attached to the contact finger, scrape bare copper first, nick a edge and peel off a good contact, using high temp epoxy glue them down over lapping original bare track and wait for epoxy to cure. Once done, bridge the bare track to tail end of replacement track where contact is with small wire and solder, flux.
This is professional track repair where there is absolutely no choice. This is done on irreplaceable expensive boards too.
I have done peeling the tracks before to do repairs.
Absolutely cannot have tinned contact in high speed circuits as this can cause intermittent issues as soldered layer oxidizes over time.
Cheers,
Great Northern aka Canada.
Reply 3 of 6, by Horun
Actually because AGP slots do use alternating "staggered height pinchers" in the slot, those thin traces above the fatter bottom conductor part never get touched by the pinchers so you could use a thin (meaning able to paint a very non-thick line) good conductive paint (silver based, not graphite based) or even silver based "wire glue"(if done correctly) on the traces that go inside the slot. The trick will be to keep your created trace as flat as possible.
For above the slot in the green enameled area you can tin, solder wire, whatever... because they are just like any other board trace but as pentiumspeed mentioned over time the solder can degrade...
just a thought and much easier than stripping traces off a donor card. forgot to mention: I would NOT try to solder/Tin or use any wire that goes down into the AGP slot.
Reply 4 of 6, by quicknick
Thank you all for your input. Not particularly proud of how this turned out, but I had to quickly check if the card is at least a bit alive so pentiumspeed's method was out of the question (mainly because I'm lacking the high-temp epoxy and the experience 😁 )
970.62 KiB
At the initial check-up I found 4 broken traces, but more of them broke up at the boundary between the gold-plated finger and plain copper when I went over them with the soldering iron, so it ended up with 13 bridge wires (not all were needed, but I put them on all traces that looked very bad). Some of the larger traces were ok with just tinning. The end-result fits nicely in the socket, and it has survived at least one insertion and removal cycle 😁
The Voodoo's alive, but it's not very healthy:
661.2 KiB
546.01 KiB
This means more work to do, checking for discontinuities around the upper four RAM chips. I'll come back with an update in the next few days.
Reply 5 of 6, by Sphere478
For such small work, that is pretty good.
Reply 6 of 6, by Thermalwrong
Nice job fixing that, it looks quite tidy 😀
I have a Voodoo 3 that's got the same mess on the screen, but that's my fault for flexing the card fitting a screw-on heatsink. I think I detached one of the BGA pads for the memory potentially.
