First post, by mwdmeyer
I picked up a Microsoft IntelliMouse 1.1A Serial mouse and when booting my 286 or 386 with cute mouse it isn't detected.
If I boot the computer with another generic serial mouse and then swap the mice while the machine is running it works fine.
Any ideas? Do I need a special driver for it?
Reply 1 of 2, by Horun
Could be a bad mouse or the Cute mouse driver does not initial the MS mouse but does the generic. Have you tried a real MS mouse driver ?
My experience with serial older MS mice is that early versions can be picky so use a true MS mouse driver (usually v7.6 or v8.2) even though it takes more ram than other drivers.
TBO I never use cute mouse driver. If MS mouse use MS driver, if Logitech use their driver.... but that is just me...
Reply 2 of 2, by mwdmeyer
Thanks for the reply. I tried it in a Windows98 machine and no issues, works fine.
I’ll update after I test another driver in dos.
