First post, by tenth1
First I would like to give some kudos to the creators of this piece of tech. My Master of Magic works great with this program on my Win2K pro. I have to have the 1 of 3 sound effects turned off is the only problem, other than that it's much more stable a game than ever and pretty fast too!!
After getting MOM to work I tried Hammer of the Gods. I haven't had too much luck here. I was able to get the program to skip the intro using the nointro argument but wasn't able to get it to accept the z argument to get it turn turn the sound all the way off.
With intro on, and using the gui, i was able to get it to play about 10 seconds of sound before it stopped and froze.
With the nointro argument in force, it would show up the menu screen with the background picture fuzzy and the mouse working and then freeze right away.
I had vesa enabled and tried many different combos with the GUI.
I pulled the game off www.the-underdogs.org.
I wasn't able to get the setup.exe program to work. That could be a problem. I was able to get the sound set though.
I tried with both updated and non-updated versions.
Any ideas? I was unable to check the compatibility list the last few days.
If you can't see the computer info I entered when registering - I have P2-350mz - geforce2 gts 32mb - 40mb hd 32bit - sblive.
Thanks 😀
**The definition of a problem is: an undelivered communication - Hubbard**
