First post, by T-Squared
- Member
Yes, I understand this is in the hardware tab, but my conclusions have led me to believe there is a problem with the BIOS, somehow.
I'm running a Chaintech 6BTM, with a BIOS dated August 17th, 2000: https://theretroweb.com/motherboards/s/chaintech-ct-6btm
I don't know what the problem is, but Windows 98 freezes when I click on the "Settings" tab in the Display Properties, and Windows XP says "This device cannot start (Code 10)", which leads me to believe there is a bug in the BIOS... maybe?
(I use a removable drive caddy that I can swap OS drives with, to use the same motherboard.)
Are displays supposed to share the same resources, or are they separate?
The only thing that has actually worked is a pair of NVidia cards.
I've tried individual cards; Matrox, ATI (All-in-Wonder and Rage Pro), as well as the Nvidia cards, but they all have problems working in Windows when plugged into this board.
