KVM cables
First post, by AppleSauce
I just had a question , would it be possible to use any kind of ps2 extender cables on a belkin omnivew kvm in place of the ones that came with it
ie something like this:
The attachment s-l500.jpg is no longer available
, would it also be possible to use any vga cable you wanted or are the ones that come with it proprietary in some way?
Reply 1 of 6, by AppleSauce
Also while I'm here I might as well ask , I've been thinking about a potential setup involving a db25 switchbox , and using two LPT sound cards , would that even work if say the switchbox was connected to the pc with a 1-3 meter db25 cable , or would the cable be too long and cause problems with the sound cards?
This is sorta the thing id be going for
The attachment 61PV3Cn2bvL._AC_SX679_.jpg is no longer available
Reply 2 of 6, by darry
Presumably yes, if the connectors are standard and the pinout is straight through. You can use a multimeter to test the provided cables and get some with a matching pinout.
If you don't have the original cables, you might get the information you need from the manual
Reply 3 of 6, by AppleSauce
darry wrote on 2022-10-22, 05:09:
I do have the original cables but I'm not super happy with them , I guess ill use a multimeter to check the pinout like you said.
Reply 4 of 6, by debs3759
I've never had original cables with a KVM, always used standard cables off eBay. I've always assumed you can always use 3rd party cables, but I may have just been lucky.
Reply 5 of 6, by TehGuy
AppleSauce wrote on 2022-10-22, 04:48:
I just had a question , would it be possible to use any kind of ps2 extender cables on a belkin omnivew kvm in place of the ones […]
So I have 2 omniviews, the dual input and quad input with audio. I've also got 2 different types of Belkin "KVM" cables and from what I can see there's nothing special about them. First kind has the PS/2 cables 'attached' to the sides of the vga cable (as in mouse, kb, and vga are separately cabled but physically molded/tied together if that makes sense), second kind it's just all separate cables. Both work. Hell, my XP machine needs a PS/2 to USB adapter to work and the belkin doesnt care.
Use whatever you got on hand, I guess. I do have some kind of short PS/2 male-to-female extenders or something and they work, too, and I have no idea where they came from.
At some point with my quad input, I just used whatever vga and PS/2 cables I had on hand with no issues
Win98+DOS: C3 Ezra-T 1.0AGHz / P3-S 1.26GHz, 128MB RAM, AWE64 + Orpheus + Audigy 2 ZS, Ti 4200, 128GB SD card
Win XP SP3: C2Q 9650, 4GB RAM, X-Fi Titanium, GTX 750
PowerMac G4 QS 800MHz + GeForce4 Ti4200, OS 9
PowerMac G5 DP 1.8Ghz + ATi x800 XT, Leopard
Reply 6 of 6, by kaputnik
AppleSauce wrote on 2022-10-22, 05:08:
Can't see any reason why it wouldn't work, if it does with way more bandwidth intensive stuff like scanners, printers, etc. Definitely worth a try at least 😀
