Reply 1 of 6, by agent_x007
Reply 2 of 6, by mockingbird
agent_x007 wrote on 2022-10-24, 05:44:Isn't left pin on top row marked as "1" ?
Here's what it looks like:
Now, according to this photo of a general HD15 pinout, pins 4, 9, and 12 are not used:
You make a good point, if that's pin 1, then the pinout follows logically... But I have 13 pins, what combination of two pins of pins 4, 9, and 12 should I leave out then?
Thanks
Reply 3 of 6, by weedeewee
aren't the analog pins connected to the dvi ones ? ie measuring continuity between the pin header and dvi pads should give easy results.
since there's no backside visible i'm assuming that the dvi connector is only lacking the pins, but the pads/holes are available on the pcb under the connector and on the backside.
Do not ask Why !
Reply 4 of 6, by mockingbird
weedeewee wrote on 2022-10-24, 12:41:aren't the analog pins connected to the dvi ones ? ie measuring continuity between the pin header and dvi pads should give easy results.
Unfortunately (but by design) not as such, it's DVI-D, so while there is continuity (because I assume they probably share some signals), there's no correlation with all the pins.
Reply 5 of 6, by weedeewee
Did you look into it?
for VGA all one would need would be R,G,B,hsync,vsync,gnd, ddc_data & ddc_clk
Those would correspond to pin C1, C2, C3, C4, 8, C5, 7, 6 on the DVI connector.
that's only 7 signal pins, the rest are likely to be ground anyway.
though if the pads for the full DVI-I layout on the backside of the pcb are missing, my whole suggestion is moot anyway.
Do not ask Why !
Reply 6 of 6, by mockingbird
weedeewee wrote on 2022-10-24, 13:25:Did you look into it? […]
Those would correspond to pin C1, C2, C3, C4, 8, C5, 7, 6 on the DVI connector.that's only 7 signal pins, the rest are likely to be ground anyway.
Indeed! The pads are there! (six pads). Ok, I'll Ohm these out later on and report back! Thanks
