First post, by Piterx87
Hi, i have a problem with crashing 3d applications (especially 3d mark 2001 se) and games on Windows XP Pro 32 bit .
The problem arises when i set in bios FSB 200MHz for cpu (factory preset) and set memory Frequency - Auto (200Mhz). RAM is in dual channel.
1. In 166MHz FSB everything works good but CPU is not recognize correctly
2.When I leave only two sticks of memory (non dual) and set 200 MHz FSB and 200 MHz RAM, Also works ok.
I check RAM and run memtest (passed). Swap to another sticks - same problem.
I built a computer based on that specification:
AMD Athlon Xp 3000+ 200Mhz fsb AXDA3000DKV4E
Abit NF7-S
3x1GB RAM DDR 400 (GOODRAM)
GeForce 6800 GT 256 MB
PSU - I try: Ocz Fatality 750W, Yesico 420W, xclio 650W
Also i check another mainboard: Soltek sl-75frn2-rl, another GPU and there is the same problem
Reply 1 of 1, by pentiumspeed
This is correct. Always two sticks for the nforce2 chipsets is reliable, three is overloading the chipset. I once had nforce2 motherboard.
Goodram is not quality modules. Buy three sticks made by Micron, Hynix, Samsung, infineon.
Example:
https://www.ebay.ca/itm/324590467279?hash=ite … ABk9SR_SukuaCYQ
https://www.ebay.ca/itm/234670158107?hash=ite … ABk9SR7izn-aCYQ
Cheers.
Great Northern aka Canada.
