First post, by Rex
Hi, decided to get an M70 for early 2000s games as Pentium M and 6800/fx1400 are quite an capable combo in an small package for the time
Sadly soon after gpu started artifacting and I decided that it woulbe be best to buy an 7800GTX instead (they the same size made by dell and should fit right in) Saw some other threads of other people successfuly doing so on other laptops and D810/M70s too
So I put the 7800 in and... nothing, then about 30 seconds after two beeps (ram issue by dell instructions). Here is the thing:If I put fx1400 back it launches instantly and without problem showing bios enter screen.
The CPU and GPU both get the power as they heat up, the gpu fan even starts spinning at some point when it detects that it got too hot.... So any ideas?
There was this thread about 7800GTX and M70 specifically on laptop logic but sadly wayback machine only has 1st page: http://www.laptoplogic.com/resources/detail.p … fc0b740504de465
The attachment IMG_20221029_181047_1_1.jpg is no longer available
The attachment IMG_20221029_181001_1_1.jpg is no longer available
Reply 1 of 3, by Rex
Anybody?
Reply 3 of 3, by marxveix
Use 130w dell adapter first, but it should boot up with 90w also i think. I have the same 7800GTX GPU and Intel Pentium M @ 2.4GHz. I downclocked it, but i should downgrade volts also if possible. Dell D810/M70 heatsink is smaller and heat gona be issue, because of that undervolt would be good. Dell D810/M70 has at least 2xfan and its old fat laptop that i like. Still i would use X600 or GO1400 also there. Someone have working hinges, screen does not stand at its own anymore. If someone has X600 graphics for it and new hinges, i would be glad, even two hinges, then i can make second Dell D810/M70 for backup. Oh sorry, its old topic. 😀
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
