First post, by Grosvince
Hi alls
Following my topic about Socket7 CPUs (Socket 7 200MHz test), I wanted to try same benchmarks on a more modern (!) platform, as I think it's the last socket that have handled CPUs form differents manufacturer.
Mainboard is an Asus TUV4X, 64 MB PC133 SDRAM, same ATI Rage 128 Pro. I used the Dosbench compilation from PhilsComputerLab.
Unfortunately, I cannot run my Celeron 300A on this board (I hope my BE6-II is still working, so I could add more results to this bench with slot 1 CPUs).
Here are the results :
134.32 KiB
Socket 370 benchmarks
What we can see, is the C3 is a very weak CPU, @500 MHz it barely beats best Socket 7 CPUs @ 200 Mhz. Pentium III S is a very nice performer, compared clock to clock to the Coppermine (the double amount of cache ?).
Bye
Vincent
Reply 3 of 9, by Joseph_Joestar
Grosvince wrote on 2022-10-31, 07:31:
Quake in 640x480 seems to be limited to 60.6 FPS.
There is no hardcoded limit.
I had around 90 FPS on an AthlonXP system in that resolution, when using FASTVID.
Reply 4 of 9, by Grosvince
Joseph_Joestar wrote on 2022-10-31, 07:37:
I will test FASTVID !
Reply 7 of 9, by Joseph_Joestar
Grosvince wrote on 2022-10-31, 14:15:
So. No difference with fastvid : 60,6 FPS.
If you haven't done so already, patch Quake to v1.08. Also, disable VSync by editing Quake's config.cfg and setting these entries to zero:
vid_wait "0"
_vid_wait_override "0"
That together with FASTVID, should allow you to get the maximum FPS that your CPU can deliver.
Reply 9 of 9, by Joseph_Joestar
Grosvince wrote on 2022-10-31, 14:42:
But why did I get more FPS in other definition ? With the same monitor ?
FASTVID only works in pure DOS. If you're benchmarking Quake from within Windows, it's likely the GPU drivers already enable the relevant write-combining features.
