First post, by Toaster999
Hi all
I have repaired the above but CMOS settings aren't saved. I have replaced the battery of course, but the negative terminal isn't connected to anything? I have checked details/pics on this website but no joy. The negative side of the battery has no obvious connection. Jumper setting are to retain CMOS
Any ideas? Or I'm I going mad!
Thanks all
Reply 1 of 5, by Doornkaat
Usually the negative side just connects to the ground plane.
If the connection has failed for whatever reason you should be able to just solder a wire from the battery to any ground point on the board.
Or am I misunderstanding you completely?
Reply 2 of 5, by Toaster999
Hi
No that's great!al makea sense now. I guess the acid has affected the ground - I'll test it - thx!
Reply 3 of 5, by Doornkaat
Fingers crossed!
Reply 4 of 5, by Toaster999
Its fixed! The ground was eaten away so I jump wired it and bingo!
Thank you so much!
Reply 5 of 5, by Doornkaat
Awesome! 😁👍 Thank you for the update/conclusion!
