First post, by OSheaman
I have a Dell Inspiron 9100. I don't know how to check the Motherboard.
Pentium 4 3.2 ghz
512 MB RAM
ATI Radeon 9700 w/ 128 MB of RAM
SigmaTel Audio
Windows XP Pro
All games from Quest for Glory Anthology
The game is constantly jerky. It's worst when there is actual animation or movement, but the sound skips almost nonstop and the game itself is jerky to the point of unplayable. This always happens, even after restarts.
SoundBlaster being used (I'm using D-Fend v2)
VGA (I have no idea how to check the video mode)
DosBox v0.63
I've read the Readme. I've tried all the steps for memory-intense games. Nothing is working.
Reply 1 of 40, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
What about other games? Do they run better?
Mirek
Reply 2 of 40, by Freddo
Did you raise the amount of cycles?
Reply 3 of 40, by `Moe`
Whay cycles and frameskip value do you use?
Reply 4 of 40, by OSheaman
I had been using 3000 cycles, and a Frame Skip value of 0. Raising the cycles to 10,000 does not help at all.
Reply 5 of 40, by eL_PuSHeR
Use a frameskip value of 1 or 2. Barely noticeable and much less cpu demanding. 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 40, by `Moe`
And set core=dynamic, if possible.
Reply 7 of 40, by OSheaman
No good. It's still as choppy as ever. I set Frameskip to 2, cycles to 10,000 and core to dynamic.
Reply 8 of 40, by Qbix
Rank DOSBox Author
DOSBox Author
try settting your colordepth to 16 and select output=overlay in dosbox.conf
Water flows down the stream
Reply 9 of 40, by Guest
Can I do that using D-Fend? I'm not very familiar with how to work DosBox by itself.
Reply 10 of 40, by Qbix
Rank DOSBox Author
DOSBox Author
the second yes.
the first
right click on your desktop go to properties and then browse around
Reply 12 of 40, by OSheaman
Tried defragging the comp and checking for spyware to make sure it wasn't hardware, and nothing doing there. I think there's something wrong with the software, or else the configuration.
Reply 13 of 40, by Snover
Watch what processes are taking up CPU time in Task Manager.
Yes, it’s my fault.
Reply 14 of 40, by OSheaman
Dosbox. It uses about 50% of my computer's resources. Nothing else uses more than 1 or 2 percent.
Reply 15 of 40, by static-
I also have dosbox on a dell laptop (700m). I think it's the sigmatel soundcard, for some reason any sort of soundblaster output (voice or midi) causes me a lot of skipping. After I switched to MT-32 emulation, the sound was MUCH better and the skipping stopped.
Reply 17 of 40, by OSheaman
I can't seem to get to the website for the MT-32 Emulation. It's refusing my connection.
Reply 18 of 40, by OSheaman
OK, the site is back up. Let me see if I can get it to work.
Reply 19 of 40, by OSheaman
Well, I may not have installed MT-32 properly (I couldn't seem to find the .inf file I was supposed to point Windows to in the Add New Hardware menu), but I tried running the binary file and it didn't change anything. Did I do something wrong, and if not, is there anything else I can do?
