First post, by geiger9
- Newbie
Hi all. Hoping you can help me revive this Samsung S800 386 DX. It wouldn't POST, not even a beep code so I ordered a POST card and it seems like it fails on Award BIOS code 15. Code 15 is on the left and I think that means that's the last thing the POST tried to do before it failed. The codes indicate:
14: Test 8254 timer 0 counter 2.
15: Verify 8259 interrupt controller channel 1 by toggling interrupt Iines off/on.
I'm not sure how to toggle interrupt lines off/on. This is new territory for me. There is a DIP switch on the motherboard just below the keyboard BIOS chip but the manual for this board cannot be found online (at least not in the usual places) so I don't know if it's even related to the 8259.
If the 8254 or 8259 are bad and need to be replaced, can they be desoldered and new ones soldered in? Below are large pics of the computer, motherboard, POST card, and booklet.
