That would be a license disk for Compaq SmartStart release 2.30.
I've only used SmartStart 3.60 a few times 10-15 years ago and I have zero professional experience with it - I just got a copy of it with an old Compaq Proliant 1500R my high school was throwing out when I was a teenager. So I may well be misremembering some things. But basically you'd put the SmartStart CD in your Compaq ProLiant or Compaq ProSignia server and it would boot Windows 95 off the CD (with a custom boot splash screen). Instead of the desktop you'd get a wizard that lets you:
- Configure your Compaq SMART RAID controller using a nice GUI application
- Create the Compaq system partition
- Install the EISA configuration utility, diagnostics utility, and array configuration utility to the system partition (a whole lot easier than feeding the server a stack of floppies to do the job)
- Install your server operating system for you (NetWare, Windows NT, OS/2, UnixWare).
I don't recall when it asks for the license diskette - probably when its finished booting and starts the SmartStart wizard (I don't think the diskette is bootable).
I've only installed NetWare 4.11 using the SmartStart CD and I'm very fuzzy on the details. I have a feeling SmartStart did most of the job for you and if you saw the regular NetWare install program at all it was only briefly. It also installed a bunch of extra Compaq server support utilities, drivers, etc, at the same time as well as the most recent NetWare support pack. NetWare is pretty easy to install normally but doing it via SmartStart automated a bunch of stuff making it even easier.
The SmartStart pack came with the SmartStart CD plus the CDs for your chosen operating system but did not necessarily include a license for the operating system. Based on the bits of paper in my SmartStart 3.60 pack, it looks like you'd order a license from Compaq by including the serial number for your program license diskette (stickers were provided), and Compaq would send you back an activation key unique to your license diskette. I don't know if you had to enter the activation key every time you reinstalled the operating system, or if it got stored on the license diskette. I just remember that my Compaq Program License Diskette alone didn't seem to let me install NetWare - I had to supply my own NetWare license during install. But it might just be my High School didn't buy their license through Compaq and so no activation key was applied to the diskette.
The attachment front.jpg is no longer available
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
The attachment 4.jpg is no longer available
The license disk is inserted facing backwards as there is a window on the back of the package that shows the serial number on the floppy disk label.
