First post, by ziggy587
Hey everyone! First time poster here. I've been browsing the forums here recently, and this looks like a great place to ask about a problem I'm encountering.
I've recently purchased a Biostar MB-8500TUD-A motherboard from eBay. This is one of those turn-of-the-era boards that have some AT and some ATX features. So it has an AT style (5-pin DIN) keyboard port, and a PS/2 mouse port. From my testing, so far everything seems to work OK with the exception of the keyboard and mouse ports. The voltage is dropping off on them.
An image of the motherboard.
When I first received the board in the mail, I wanted to test it straight away. So I plugged in a PS/2 keyboard (a IBM KB-9930) with a PS/2 to AT adapter. The keyboard wasn't working, so I swapped it out for another random PS/2 keyboard from my stash. Some more modern Compaq, a real cheap one. The Compaq keyboard works fine. Since then, I've purchased a new old stock Acer keyboard with the AT style connector. When I plug it into this motherboard, it doesn't work. I currently don't have anything else to test this Acer keyboard with other than this motherboard. But I have ordered an adapter for it so I can use it in a PS/2 port, when it comes in I'll test it on another computer. But since the Acer keyboard wasn't working, and since that IBM keyboard worked the last time I used it, I suspected something was wrong. So I cracked open the new Acer keyboard. It looks very clean, no obvious signs of something wrong. So while the Acer keyboard was plugged into the motherboard, I powered on the board and used my digital multi meter to probe the connector on the inside of the keyboard. I was only reading something like 3.5v on the pins.
I suspected that maybe the power supply could be the issue. I was using a modern EVGA (this one) at first. The EVGA is basically brand new, I've only ever used it for minutes at a time to test various things. So I powered on the EVGA PSU with one of those little power supply testers, and probed various pins. The 5v pins were reading slightly over 5v, as expected. But I decided to swap out the PSU anyway, just to rule it out as a possible issue. So I swapped in an older Enermax. It's maybe 15-20 years old, but I bought it new and it has low hours on it. The same issue is happening with the Enermax. I also probed the 5v pins on the Enermax and confirmed it's putting out good voltage.
So today, I decided I want to test out more of this board to see if anything else might be wrong. I connected a HDD, CD drive, and floppy drive. I installed Windows 98 SE without issue and was able to boot to the desktop, with the only problem being that error message you get when Windows doesn't detect a mouse. So I powered off and plugged in a no-frills PS/2 mouse, a Logitech 2-button ball mouse. With the mouse plugged in, the computer booted to the desktop but neither the mouse nor the keyboard would work. I unplugged the mouse, and then the keyboard magically worked. So I tried the reverse, I powered off the computer and plugged in the mouse without the keyboard. It booted to the desktop, but the mouse was not working.
So I decided to use my multimeter to probe the pins of the keyboard and PS/2 port. With nothing plugged into either port, with the computer powered on both the keyboard and PS/2 port measure 5.04v on their 5v pins. But, as soon as you start plugging things in the voltage drops. With the Compaq keyboard plugged in (the only keyboard I have that works with this board) the Ps/2 port measure 3.75v, but it actually measures lower if I turn the num/cap/scroll locks on. I guess the LED for those locks draws a little more current so the voltage drops. With just the num lock on, the Ps/2 port measures 3.7v. With just the caps lock on it measures 2.19v. With the num and scroll lock on it's 1.993v, and with all three locks on it measures only 1.905v. So, no wonder the mouse isn't working, there's not enough voltage!
Looking at the motherboard, the keyboard and Ps/2 ports are very close to the AT main power connector. So I would have to assume that the 5v pins on those ports are connected straight to the 5v pins of the main connector. I don't see any major components in between. I guess next I'll have to back trace the 5v pins from the connectors and see if there's any components that could be causing the issue, but there can't be much if any. At least, I'm assuming the power pins are connected to the 5v rail. Or are they actually connected to an IC?
This motherboard has a footprint for the ATX 20-pin connector, but they did not populate it. I did a continuity check between the footprint and the AT power connector pins, and it seems that all the traces are there and they just decided to save the money on the connector. I don't see any missing components around the power connectors. So I'm thinking I can solder in the 20-pin connector and use that instead of the AT connector. I don't have any AT power supplies, only ATX. So for right now I'm using one of those ATX to AT power adapters. I'm wondering if there's possibly an issue with the adapter. I mean, it seems to be wired up correctly, but I wonder if there's a current issue with it? I have a 20-pin ATX connector on order, so once I get it in I'll install it on this motherboard. That'll allow me to use a power supply without any adapters. So I can rule that in or out as the issue.
But the weird thing is that everything else seems to be working fine. Again, I used a FDD and CD drive to install Win98 to a HDD. And once it boots to the desktop, aside from having no mouse, everything seems to work fine when I'm poking around on the computer. So the +5v going to those drives seems to be working OK. And when I probe an unused Molex connector, it's measuring slightly over 5v as normal. It's just the keyboard and PS/2 ports that are having the voltage issue.
Has anyone ever encountered this type of problem? Any suggestions on what I should do? I'm actually still in the return window for this seller on eBay, but I'd really rather not have to return it. I would much prefer to fix it if I can. But aside from ruling out the PSU adapter, or checking to see where the 5v pins go, I'm out of ideas. If it turns out to be an IC, then I guess there's nothing I can do to repair it. I mean, I suppose I could make an adapter that disconnects the 5v from the ports, and instead uses power from something else, but that would be kind of ridiculous. Hmm, maybe I could do that to at least test it.
Any help is appreciated!
Reply 1 of 16, by Horun
ziggy587 wrote on 2022-11-07, 01:09:
The grey things called F1 and F2 are a fuse for the KB and PS2 port, maybe F2 is for the USB power. Generally the +5v from the PSU connector routes around and goes to a fuse then to the KB.
F1 is near corner of the board by the KB port, F2 is at end of first PCI slot.
I suggest you check the volts across the fuses (specifically F1 first) as it could be near burned and acting as a resistor, which would show a voltage drop across when a KB is actually connected.
You should also check the traces from those fuses (again start with F1) to the +5v PSU connector and from the fuse to the KB connector.
In an emergency you could direct wire from the KB +5v pin to the PSU +5v but is not recommended....
Reply 2 of 16, by ziggy587
Thanks, that helps a lot!
I see +5v going to a small electrolytic cap, then to the F1 fuse. From the fuse it routes to a small SMD chip, 0805 in size I think, but I don't know what this component is. The signal jumps across this component and then to the power pins on the keyboard/mouse ports. Checking from the +5v pin of the main power connector, resistance is very low across the cap and fuse (about 0.2 ohm). But I'm measuring 6.14 K ohm across this unknown chip component.
The other 0805 components in this area, I can see they are clearly marked as capacitors (C7 for example). But this unknown components, I cannot make out what the silkscreen is. Looks like two lines, maybe L1?
You can see the thick trace coming off the fuse, going to the unknown component.
I was checking resistance across these components because it's less risky tracing everything out without power (to avoid shorting anything and causing further damage). I can check the voltage across the fuse though.
edit: OK, I checked the voltage. I'm getting 5.02v across the fuse. But 3.7v at the KB/mouse ports.
Also, I forgot to mention. If I power the computer on with nothing plugged into the KB/mouse ports, they will measure 5.01v. It's only when I start plugging things into them that the voltage drops.
Reply 3 of 16, by Horun
Ahh yes many have a very small inductor for HF filtering. Can you try to resolder one side at time (let it cool before trying otherside) and see if it makes a difference, could be a cold solder joint.
The inline inductor should not be more than a few ohms as it has to allow up to 500mA thru with little v drop for the KB...
If that does not work you can short across it (should not hurt) as it just makes sure some KB noise does not come back into the 5v lines but am sure there are dozens of caps from 5v to ground all over the board.....
Reply 4 of 16, by ziggy587
Since I was probing the inductor from the top of it, and not from traces, wouldn't that mean that the resistance across the inductor is indeed very high? I can try and reflow the solder joints anyway. What would an appropriate value be for this inductor? If reflowing doesn't help, I can short it to test with. But as a permanent fix, I'd rather replace it.
Reply 5 of 16, by Horun
One of my KB controller schematics lists a 3uH on the data, clock and +5, the other schematic just calls them a RFC...🤣. Let me check some archives.
added: the Holtek KBC datasheet schematic shows no RFC, just a 47pF cap to ground...
Yeah shorting it will not hurt for testing.
Reply 6 of 16, by ziggy587
Thanks so much for your help!
Reply 7 of 16, by Solo761
I had similar issue on one of my mainboards, one newish keyboard worked, but most did not. One even worked "half way", worked fine until I turned any LED on keyboard then it started to turn off/on.
When I tested voltage there was huge drop the moment keyboards were initialized. The one that worked actually was able to work with below 3V voltage and that's why there were no problems...
In my case motherboard had transistor to control power to AT - PS/2 ports and it went bad. When I replaced it all keyboards worked.
If everything else fails try tracing 5V path(s) from connector to see through which components it goes. Culprit is somewhere along the way.
Reply 8 of 16, by bakemono
ziggy587 wrote on 2022-11-07, 02:24:
If you have a 5V drop across the fuse then I'm going to say the fuse blown. The only reason you can read any voltage at all at the ports is because a high logic signal somewhere is backfeeding a pull-up resistor. (Like when you plug Sega control pads into an Atari...)
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 9 of 16, by ziggy587
bakemono wrote on 2022-11-07, 09:51:
Even though I'm measuring near 0 ohms across the fuse? And the inductor is measuring 6.14 K ohm? If the fuse was blown, wouldn't I get no resistance reading at all across it? Or as Horun stated, it could be on the verge of blowing. I can try replacing it. Does anyone know what rating I should get for such a fuse?
Reply 10 of 16, by Solo761
If the fuse is blown resistance would be infinite, i.e. broken connection.
But I'd guess problem is elsewhere, if fuse was the issue none of the keyboards would work.
How you tried checking voltage on both ends of the fuse (voltage, not resistance, black probe on GND, red probe first on one end, then on the other, just to be sure 😀 ) while it's turned on and keyboard plugged in? If it's 5V solid on both ends then I think the problem is elsewhere.
I had similar behaviour with Commodore 128 PSU, it "worked" while not plugged into the computer, all voltages read fine. But when I tried to turn the computer with it nothing happened. Turns out wire in the fuse was broken, but made contact, so when I measured it unloaded it seemed fine, but under load it would bend and loose connection.
That was "classic" glass fuse, this is different, but who knows, maybe it's possible that something like this cold also happen.
Reply 11 of 16, by weedeewee
that tiny inductor isn't supposed to measure >6K ohm. it's likely broken. replace it or bridge it with a wire.
Do not ask Why !
Reply 12 of 16, by ziggy587
Yes, I can measure 5v on both sides of the fuse while a keyboard is plugged in. The voltage definitely only drops after the inductor.
I have removed the inductor and jumped the pads for it. Now I'm reading 5.02v at the power pins for the KB and PS/2 ports... While both a keyboard and mouse are plugged in! So, confirmed, it was the inductor that was the issue.
Moreover, it seems the inductor was affecting some other things that I was unaware of. When I booted to Windows 98 for the first time after replacing the inductor with a jumper, the New Hardware Wizard auto detected a bunch of things. The mouse, of course. But then a communications port (twice) and a printer port. I guess that's the two serial and one parallel port that this motherboard has. So it would seem that the inductor was affecting those ports as well, and I just didn't know it since I have yet to test them. You can see in the last picture that I posted, from the inductor the trace goes to the KB port, but it also goes to C86.
The next time I place an order with DigiKey, I will order a 3µH inductor to replace the one that I removed from the board. Unless someone suggest another value. Also, now I'm kind of nervous about those fuses. Does anyone know an appropriate value for a replacement?
After shorting the pads for the inductor, I've had the computer powered on for at least an hour now. I've done some minor poking around in the OS, and typed a bunch in Word Pad. No issues as far as I can tell. Thanks, everyone!
Reply 13 of 16, by Horun
That is good news. Interesting that all that "new hardware" was found but that could be just because the Keyboard was found which then triggered more items found...
Any SMD Inductor from 1uH to 3uH should work fine as long as it can handle 1 to 2 Amps and the DC resistance is less than .2 ohm (Or else V.drop could be to high under max load) IMHO.
Just for reference (this one is only 2mm long so you will need to measure yours and 130 milliOhms or .130 Ohms :
https://www.mouser.com/ProductDetail/Murata-E … jgC4%2FQbDm8%3D
Those fuses are typical a 1 Amp slow-blow radial lead, doubt you will find any that look exact like yours but these would work, anything similar would be good as these can tolerate the in-rush current to the keyboard that can happen on power up:
https://www.mouser.com/ProductDetail/Littelfu … prZKaU3KQ%3D%3D see datasheet
Reply 14 of 16, by ziggy587
Thanks! This will be one of those cases where the DigiKey or Mouser shipping will cost more than the parts, so I'll have to wait until I need some other stuff before I order the inductor and fuse. But I will update this thread once I have it completed.
Reply 15 of 16, by ziggy587
I got the inductor in and replaced the jumper wire on the motherboard. The keyboard still works, and with the mouse plugged in. I'm now reading 4.7v at the KB and PS/2 ports. Before with the jumper wire it was measuring 5.02v. I don't know if this is normal, but everything seems to be working fine so far.
Here's the exact part that I ordered: https://www.digikey.com/en/products/detail/mu … 1R0NGRD/4358093
Thanks again for your help, everyone!
Reply 16 of 16, by Horun
Great !! yes normally you would see a small voltage drop across the inductor with both KB and mouse attached, mostly from the KB.
Being it is many turns of a very fine wire wrapped around a ferrite core (encased in ceramic, epoxy or plastic) there should be some V. drop, 0.3v under full load should be fine....just thinking out loud 😀
