First post, by DundyTheCroc
I was able to get Voodoo 2 for reasonable price and decided to build "top" periodic correct gaming PC for 1998.
After cleaning some old storage rooms at work there was a nice find, brand new Asus P2B-S MB, even with book an CD.
CPU is PII450Mhz, 512MB or RAM and ATI Rage 128 AGP for primary VGA. Time to put all part together and see if they work...
222.06 KiB
Reply 1 of 11, by Joseph_Joestar
DundyTheCroc wrote on 2022-11-12, 17:50:
Nobody had 512 MB on a consumer PC in 1998. Brand new computers from December of 1998 were sold with 64-128 MB at most.
To be clear, I'm not saying you shouldn't put 512 MB into your system. Just pointing out that it's not what people were using back then, other than in servers.
Reply 2 of 11, by DundyTheCroc
Just imagine, that you are very rich and want all 512MB 😀
Here is my test setup, unfortunately my periodic correct SCSI drive failed, replaced with 18.2GB Compaq BD018734A4.
Audio card is CT2940 for now, not sure what to use next, SB Live!, Yamaha 724 or keep it simple with AWE64?
And yes, the pass through cable is home made for now.
239.86 KiB
Reply 4 of 11, by DundyTheCroc
Not sure where that blue heatsink came from, maybe some swap many years ago.
Here are some results, PII450@504Mhz (112MHz FSB), 112MHz memory, default benchmark aps settings :
34.86 KiB
44.13 KiB
55.46 KiB
This is my first Voodoo 2 card, does it run normal or slow?
Reply 5 of 11, by chinny22
Doornkaat wrote on 2022-11-12, 22:11:
That blue heatsink is very nice!😃👌
Dell had blue heat sinks (dell part number 66054) but no fan so that was a pointless fact 😜
Reply 6 of 11, by Doornkaat
chinny22 wrote on 2022-11-14, 12:48:
I may have become a fan of those heatsinks after looking up that part number so not a pointless fact at all!😉
Reply 7 of 11, by DundyTheCroc
There is also 89504, black, with fan, this one is in Dell GX1:
223.26 KiB
204.31 KiB
Reply 8 of 11, by Shponglefan
DundyTheCroc wrote on 2022-11-12, 19:08:
What OS are you planning?
If you're planning Windows 95 or 98, I'd consider an Aureal Vortex2 based card for A3D sound support.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 10 of 11, by DundyTheCroc
Shponglefan wrote on 2022-11-14, 15:38:
Windows 98SE and DOS, does Vortex2 work fine in DOS?
Meatball wrote on 2022-11-14, 15:55:
Around 3000-3300 3DMarks ('99) is normal for a single Voodoo2 at 800x600.
Thanks!
Reply 11 of 11, by DundyTheCroc
All works stable, so moved the parts in a case. This is the only case I have, that is big enough to take in Asus P2B-S MB.
69.05 KiB
209.68 KiB
