First post, by kaputnik
- Oldbie
Scrapped a bunch of PCB:s from an old automation system the other day. Amongst other things I salvaged a bunch of EEPROMs, Xicor X2864AD to be specific, that might be useful for a retro computer hobbyist. Would guess they're from the early nineties.
Popped a few of them in my new Xgecu T56 programmer to check them up. The programming software complained about pin errors with some of them, different pins on different chips. Others would detect and erase/program successfully according to the programming software, but when verifying against the buffer, there were errors. None of the chips I tested worked without remarks.
I did of course clean the pins to ensure good connection before plugging the chips in the programmer.
I know for sure the EEPROMs were working when the PCBs were taken out of commission about 10 years ago. Since then, they've been stored in a container onshore, in suboptimal conditions. They've never been wet, but would guess the air in the container has been quite humid now and then. Also guessing the temperature has ranged between -15 and 40 deg C or something like that with the seasons. It's well within the specified storage limits, but anyways.
In my experience old electronics generally is very abuse resistant. Tried to find some information if it's normal for old EEPROMs to go bad with time, but did of course only find explanation after explanation about data retention time being finite, nothing about aging of the actual hardware.
Since I just got the T65, I don't have a lot of experience with it. It does read all the 27C series EPROMs salvaged from the same PCB:s perfectly though. Used the preset for Xicor X2864AP, there's no entry for X2864AD, but guess that doesn't matter? Didn't find any data on the difference between the AP and AD versions.
So, what's the opinion of the experienced people here? Is it normal for old EEPROMs that has been stored under less than optimal conditions to go bad on hardware level, or is it perhaps the programmer and its settings I should look at? In the first case, is there anything you can do to recondition them?
