First post, by haker120
- Member
I got myself PCI card that finally works as PCI sound blaster to me. However, when I set digitized sounds and music to SB compatible what I hear is clean but when I set anything MIDI no matter port 240 (default) or 220 music crackles a lot what is unbearable to me. Is my card broken or is it normal behavior for out of spec environment? My OS is win98, device is Futro s400 and sound card is ESS Maestro-2 on ES1968S chip. I can stay with Sound Blaster only if MIDI behavior is normal, if not I can return this card yet.
