First post, by dontbugster
Hi!
It's an ESS Solo1 over a Celeron PC.
I got this card fully working on pure DOS, Windows 98 SE and DOS program over Windows 98SE.
It's funny as it provides general midi capabilities with native FM synth when running DOS over Windows.
I had to change bios battery so I had to fight a bit with my BIOS to get the card in IRQ5 again. Now it works perfectly over pure Dos and also over pure Windows, but no legacy audio capabilities are now present over Windows.
Is there any trick to bring them back? I had it, same os, same card, same mainboard.
I have tried last win98se and winMe drivers, but they didn't bring this legacy audio back over windows.
Reply 1 of 15, by Duffman
still using the same VXD driver?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 2 of 15, by Hezus
You'll have to check the adress and IRQ settings in Windows device manager. Check to see if they match the SET BLASTER environment in your autoexec.bat
Visit my YT Channel!
Reply 3 of 15, by dontbugster
Hezus wrote on 2022-11-19, 21:57:
Replying both
It's a SET BLASTER A220 I5 D1 T4
Uses solo.sys 5.12.01.3047 and mmsevldr.vxd 4.10.1998
IRQ 5 in device manager, while I/O are PCI values: CC00-CC3F, ...
Reply 4 of 15, by dontbugster
Oh now I see uninstalling the drivers didn't actually uninstalled them, so always ended with same winMe drivers
Reply 5 of 15, by dontbugster
But With win98 drivers and legacy emulation device present, I only recovered FX, but General midi is silent
Reply 6 of 15, by Joseph_Joestar
dontbugster wrote on 2022-11-20, 09:12:
The ESS Solo-1 doesn't have a built-in General MIDI wavetable. It only has FM synthesis (ESFM) and SBPro support. If you want General MIDI with VxD drivers on the Solo-1, you either need to connect a wavetable daughterboard or use an external MIDI device like a Roland Sound Canvas.
However, with WDM drivers only, the Solo-1's native ESFM mode can be used to emulate General MIDI. The results are kinda odd, but it does work.
My retro stuff
Reply 7 of 15, by dontbugster
Joseph_Joestar wrote on 2022-11-20, 09:20:
Which ones work best? I had a zip with at least 8 versions of the drivers. Latest ones from winme lack dos support inside windows.
Reply 8 of 15, by Joseph_Joestar
dontbugster wrote on 2022-11-20, 14:53:
For DOS gaming, I had the best results with version 4.12.01.1165.
You can get it from Phil's website.
My retro stuff
Reply 9 of 15, by dontbugster
Joseph_Joestar wrote on 2022-11-20, 15:41:
I ended installing a Microsoft certified newer version because the win9x drivers were changing sound blaster port also for native DOS and kept failing on dos over windows...
It should be some combination for the BIOS that I had... The old times of plug and Pray I guess
Reply 10 of 15, by henk717
The ESS Solo-1 does have Wavetable midi support in Windows but its a seperate installation, the driver I use is archived on my storage server http://storage.henk.tech/Drivers/ .
The card is picky with its IRQ's, I personally do not run the card at IRQ5 but at one of the higher IRQ's with IRQ5 and IRQ7 reserved for the PnP driver to claim by itself.
That way the card runs on an IRQ it likes, and the soundblaster emulation still runs on IRQ5. I basically just keep bumping the IRQ it runs on by one until I get something thats stable for all the games I use it with.
Reply 11 of 15, by Joseph_Joestar
henk717 wrote on 2022-11-25, 15:28:
Is that the one from Terratec or something else entirely?
file.php?id=140320&mode=view
I did try the Terratec softsynth at one point, and it sounded decent under Windows, but it could not be used for General MIDI music in DOS games.
My retro stuff
Reply 12 of 15, by henk717
Joseph_Joestar wrote on 2022-11-25, 15:45:
I usually use the Soundblaster Audigy inside Windows (I have both in the same system) so I had to double check, but you are right. Its a different unbranded version of the same driver it does not support software wavetable inside DOS applications, but it does have software wavetable in Windows. So compared to other softsynths that can be installed on any card its not more useful unfortunately.
In comparing it I did notice my driver have something the terratec driver and phil's driver do not have, which is AUDIO3D support from Sensaura. Haven't tried it out but that does look interesting. I was always under the impression this card didn't support it and didn't notice I actually had a rare driver that has that bundled.
Reply 13 of 15, by Joseph_Joestar
henk717 wrote on 2022-11-25, 16:49:
That's pretty unique indeed.
You might want to ask one of the mods to mirror that version on Vogonsdrivers.com. If Sensaura does work with that driver, then having some form of A3D and EAX support would make the Solo-1 even more versatile for Win9x gaming.
My retro stuff
Reply 14 of 15, by dontbugster
Did it gave wavetable or at least sound blaster emulation using Dos over windows?
I also have now nice wavetable under pure Windows and certified drivers by using es1938-46win2k. It says 2k but they work on win98
https://www.driverguide.com/driver/detail.php?driverid=26673
Reply 15 of 15, by crazii
I remember the BLASTER env will be overwritten by the DOS emulation driver in windows, usually it is the same values as in DOS. If not, you probably need to set it in devmgr - the resources tab. Otherwise the games will only have sounds in either DOS or windows but not both or you need reconfigure driver each time you switch the OS. set it to auto or manual and then reset the pc, the BLASTER env will probably change in windows.
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
