First post, by CachoAlpuy
Hi, I have an isa-486sv2 Asus motherboard which won't post, I repaired a broken trace due to battery leakage and checked the rest of the traces.
If I power it with the kb controller chip the post card doesn't show any code, and if I remove the keyboard controller I get the codes like in this video, the codes loop:
https://youtu.be/BIph08LbXIA
How can I trace the problem?
Reply 1 of 1, by rasz_pl
keep looking for more corrosion damage, maybe under keyb controller socket, maybe under those two chips inside it, maybe under ISA slot
https://github.com/raszpl/440BX Reference Design adapted to Kicad
