First post, by moulder
Hi,
I have problem with Interstate 76. After few minutes it hangs and show error "interstate 76 grtexdownloadmipmap mipmap cannot span 2 Mbyte boundary". What could be cause?
My spec: PIII 700 MHZ, 2x Voodoo 2 in SLI, 256 Mb ram. I 've installed newest patch for I76.
Reply 1 of 2, by leileilol
Disable SLI and limit texture memory to 2MB. You could also run it in Direct3D which would be fine at the expense of hand texture resolution
long live PCem
FUCK "AI"
Reply 2 of 2, by moulder
leileilol wrote on 2022-11-30, 01:19:
Now it seems ok. Thank you.
