First post, by Iarsin
Hi,
I'm currently got a Siemens Nixdorf Informationssysteme SNI with the gravure "PC 4DX2/66" on the desktop case top rear. I think, it might be a consumer version of the PCD-H/PCD-4H and it got a mainboard D756-V with ISA/VLB riser card 3* ISA. Installed is an old Windows 95a OSR1 system. In the device manager the IDE/EIDE standard driver shows a yellow exclamation mark '!' which indicates error code 10 for the chipset OPTi 82c498/82c206, I guess.
also the drives aren't showing up under drives in the device manager, but they are working. I think, they might not working in DMA mode and are maybe slower as possible.
So, I'm wondering, if there are some BUS drivers, that will correct this issue.
Reply 1 of 1, by Iarsin
Would this apply to the issue? https://jeffpar.github.io/kbarchive/kb/154/Q154435/
Edit: No, that didn't solve the issue with the IDE Standard driver. It has still the yellow exclamation mark and error code 10 ("This device cannot start." Recommended resolutions: Update the driver , https://support.microsoft.com/en-us/topic/err … fa-6bca0456324e)
So, I'm still searching for the appropriate driver. Q154435 remideup.exe was only for issues in removable drives. I installed successfully that patch either.
