First post, by MobyGamer
- Member
I wrote a progam for vintage DOS computing that I thought VOGONS people might be interested in: It's called SOFTHDDI, and it implements in software what the "HDD Clicker" does in hardware. And while I was writing it, I added the ability to show hard drive activity onscreen and on the keyboard LEDs as well, for any system that lacks a hard disk LED.
Download SOFTHDDI: https://github.com/MobyGamer/softhddi/releases
Github repo with assembler source code and full documentation: https://github.com/MobyGamer/softhddi
I made a video about it, going into the justification for making it, and demonstrating it on real hardware: https://youtu.be/v5XTid2S1iE
BTW, SOFTHDDI does nothing in DOSBOX, because DOSBOX doesn't do disk access via traditional Int 13H calls. You can install it, and no harm is done, but the indicators never fire. The program is meant for vintage DOS hardware.
