First post, by sirotkaslo
Hi,
I'm having issues with usb 2 drivers for this pc. It uses SiS 651B and SiS 962L. Official drivers install normally (USB SiS 7001) but I only get usb 1 speed. Found a bunch of posts on google with people having the same issue but unfortunately no fix. Has anyone found a driver that works as it should and provide usb 2 support?
thanks!
Reply 1 of 1, by sirotkaslo
I finally found the right driver, everything from sis doesn't work, but these VIA NEC drivers did the trick.
I have attached them to this post in case anyone else needs them.
    VT6202.rar
    1.75 MiB
    32 downloads
