Win2K and dosbox 6.0
First post, by skirmish
I am having alot of trouble getting dosbox to run at all under win2k. Once I install it and run it two screens come up one is a dos prompt and the other is a blank ap screen if i select the dos propmt fast enough it outputs a message about something or other then closes it's self. can anyone please give me some advice on this matter?
Reply 1 of 2, by HunterZ
What version of DOSBox are you trying to run? 6.0 is not any version I've ever heard of.
You might try changing the output= setting in your dosbox.conf or updating your video drivers to fix the blank screen problem.
Reply 2 of 2, by Snover
Sounds like an SDL parachute caused probably by a 24-bit colour issue. Switch to 16-bit or 32-bit colour.
Yes, it’s my fault.
