First post, by donny
Hi there !
I wanted to shared an observation on my 486-VIO-GT motherboard, when running.
I observed the board with some thermal imaging cam and noticed that two resistor networks (or resistor packs ? RP20 + RP21) get quite hot (>50 Celsius) after few minutes.
This does not feel normal, or is it? All other resistor networks on the board keep absolutely cool. Nothing exceeds those two components, temperature-wise, on the whole board.
Do you have any suggestions or experience with such an behaviour?
I might add: The board works fine. I checked all the jumpers against the manual I found in Ultimateretroweb, and everything seems to be correct (CPU type, Clock etc.).
PS: 4 pictures attached.
Many thanks in advance and Greets,
Sebastian
Reply 1 of 6, by majestyk
Do they still get hot when the cache / TAG chips are absent?
Reply 2 of 6, by donny
Hi !
Thanks for your quick suggestion, nice idea. I just tried that, and measured as well as touched them again.
For short: Behaviour unchanged. Quickly rising in temperature after power-on.
I dared to wait a little bit more (30 Mins): It seems as that it peaks at ~56 Celsius and is holding it there.
Don't know what to think of that...
Regards,
Sebastian
Reply 3 of 6, by majestyk
Have you tried with a different set of memory sticks?
What´s the resistor value printed on the arrays?
Reply 4 of 6, by donny
The description reads: 10Z221/331G (Yageo), on both of them.
Switching the RAM e.g. to the 72-pin bank didn't change behaviour.
Reply 5 of 6, by majestyk
221 means 220 Ohm, if the resistors would be between 5V and ground (worst case) each resistor would dissipate 0.11 W power. These arrays are rated for 0,125 W so this would still be within specs. The whole array would dissipate 0.99 W hence the temperature.
Are you sure the mainboard is a 486-"VIO-GT" and not GIO-VP, GIO-VT or GIO-VT2?
Reply 6 of 6, by donny
Good Morning! Thanks for the resistor info, wasn't to interpret it that way.
Yes, I'm sure regarding the board type:
Edit: Ohh, now I see. I mixed it up in the first post 😀 My bad.
