First post, by Intel486dx33
Hey Guys I have a NEW Project.
My WD MyCloud NAS Drives keep dying ( Bad Capacitors, Bad Drives, etc )
So I have decided to Build a NAS or File Server ?
What Do you think ?
Should I Build a NAS or Windows File Server ?
I want to repurpose an old “Lenovo Thinkstation TS-140”.
I purchased a couple of these a while back and never really used them so
I think this will be the perfect project for them.
I want to load them up with 16gb RAM
They Have a Quad core Xeon CPU ( Haswell )
( 5 ) Sata ports.
( 6 ) Port PCIe Sata Adapter
So I want to run my primary Sata SSD and Cache SSD off the Motherboard
I want to put in (4) Hard drives for Storage off the PCIe Sata Adapter.
I am only running Gigabit Ethernet because I don’t want to rewire my house and Gigabit is all I need for now.
I don’t do video editing. And Gigabit is fast enough for my home devices. I wired my house back in 1999 with Cat-5
Ethernet ( Gigabit ).
I might upgrade to Cat-6 , 2.5gb. Ethernet in future. But then I will have to by NEW Switches too, And Our Internet Service provide router
Is only 1 Gigabit.
I purchased a drive bay cage to put inside the TS-140 to add the additional hard drives.
Everything fits perfect.
What do you think ?
I just like the versatility and easy repair and setup of building your own NAS/File Server and to having to rely on a pre-build NAS
With NO Upgradability options or repair options.
This is just for DOS files and games and small Programs before 2010 mainly.
Reply 1 of 6, by Hippo486
I have a NAS I built based around a HP Prodesk 600 SFF and Openmediavault
Its current uptime is over a year, hasn't skipped a beat. Cheap and upgradable.
Its main uses are as a media file server for my Kodi PC attached to the TV, a backup server for the Windows Computers and as a file server for my retro computing.
As far as the retro computing goes, I've only used it with Win 98 SE so far, loading ISO images with Daemon tools, to save burning disks.
I think DOS can access Samba shares through a variety of means, google shows a few results, I'm sure someone more knowledgeable on this can help.
Reply 2 of 6, by Kreshna Aryaguna Nurzaman
Hippo486 wrote on 2022-12-31, 12:56:
I have a NAS I built based around a HP Prodesk 600 SFF and Openmediavault […]
The last time I used DOS to access a shared folder, I was logged in using Novell NetWare client. I didn't know which version though, it was 1993 and the DOS PC was a part of a computer lab whose programming course I attended. But I remember we accessed the coding practice files on the said shared folder, hence the need to log in using Novell NetWare client.
Can a DOS PC with Novell NetWare client access a Samba server?
Kreshna Aryaguna Nurzaman.
Reply 3 of 6, by keenerb
I have set up a dedicated file server to share data with my MSDOS/Windows9X/XP+ machines.
It's a Debian linux host, running on a raspberry pi 400 (any hardware will do.)
For presenting files, I use a combination of several applications:
etherdfs: Uses packet driver to map a drive letter as a local hard drive, very small memory footprint.
Etherflop: Uses packet driver to create a virtual floppy drive using remote image files, supports up to 32mb virtual floppy even on a machine with only 360kb physical drives.
Python's built-in http server: presents my vintage file repository as a simple web listing for easy file downloads on basically anything with a functional web browser
browservice: A proxy that does a FANTASTIC job of presenting modern web pages to vintage browsers.
Samba: Shares the same folder root as the etherdfs share. Allows me to continue playing the same games on my desktop via dosbox as I play on my MSDOS actual hardware.
Telnet: For managing the debian system from vintage hardware if necessary.
Reply 4 of 6, by Intel486dx33
Yes, I have not decided on an operating system yet.
I was thinking about Windows server and administer it with Remote Desktop.
Reply 5 of 6, by keenerb
Intel486dx33 wrote on 2022-12-31, 17:44:
You'll miss out on a LOT of interesting utilities running windows.
Reply 6 of 6, by davidrg
Kreshna Aryaguna Nurzaman wrote on 2022-12-31, 13:20:
No. Samba implements Microsofts SMB protocol while the NetWare client implements (the client half of) Novells NCP protocol. The NCP equivalent of Samba is Mars NWE which implements NetWare-compatible File & Print services on Linux.
There isn't any useful way of getting network drives on DOS from a modern windows host. The old Microsoft SMB client for DOS uses a lot of conventional memory and can't talk to any modern version of Windows so if your plan is to use that you'll need to run something older. If you can run Windows NT 4.0 Server then you can pickup a copy of Microsoft File & Print Services for NetWare and run the Novell NetWare client on DOS which uses vastly less conventional memory on a 386 or better.
Alternatively if you run Linux then you can run Mars NWE to do the same job (it implements the NetWare protocols on Linux). I wouldn't bother with Samba just because the DOS client is so memory hungry and Samba itself is slowly dropping support for older SMB versions. EtherDFS is worth looking into too - easier to setup than Mars NWE but a bit less flexible.
