First post, by sndtst
 - Newbie
I have an Aopen Socket 7 Motherboard with an Award BIOS that while it recognizes various SD and CF IDE adapters (and I can fdisk and format) refuses to boot from them (just hangs). Every mechanical hard drive I've tried (regardless of size) has worked just fine. I had assumed it was some incompatibility with the BIOS but I just tried the latest build of XTIDE (on a 3com network card) and while the SD adapter is recognized it still won't boot from it after I complete an MS DOS 6.22 install. Any ideas on what I can try to debug this?
A Sound Test for as many games as I can find at SNDTST.com
