First post, by Nexxen
I'm looking for a debug card with pcie connection, before I order and make a mistake, do you have any suggestion?
The one I think is right cost in the tens of €, or it's a laptop card costing nothing.
I now have some motherboards without a PCI slot so I have to buy a new card to try to understand what is going on.
Thanks!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 1 of 5, by Horun
Good question ! I do not know but would like some good info on any that members have bought and used.
Reply 2 of 5, by rasz_pl
Im not sure PCIE even transmits IO port writes
laptop mpcie cards are special - they dont connect to PCIE switch but instead to LPC pins in some notebooks Mini-PCIE slot:
https://testere-adaptoare.sorinescu.net/drive … CI_miniPCIE.PDF
"3. The Mini-PCIE interface in the Combo-POST CODE-Card
Mini-PCIE is used as a trend in the new notebooks. Compared with
Mini-PCI, Mini-PCIE occupies less space. This Combo-POST
CODE-Card doesn’t use all of the Mini-PCIE bus pins. And only the
below pins are used: PIN-8, PIN-10, PIN-12, PIN-14, PIN-16, PIN-17,
and
PIN-19. In the Mini-PCIE spec, those pins are reserved, and it is not
standard, so some of Notebook manufacturers define it as a LPC
POST CODE-port."
another one same info http://bitsavers.org/test_equipment/sintech/S … _user_guide.pdf
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 3 of 5, by RussD
Your best bet is a debug card with LPC support, such as:
https://www.ebay.com/itm/323558941619
unfortunately these aren't cheap, you'll need to figure out how to wire it up for each individual motherboard, and there's no guarantee it'll work with any given motherboard.
Reply 4 of 5, by Nexxen
That's what I thought, it's the costly one and it's not as straight forward as the old PCI/ISA ones.
The price is high enough to make me ponder.
Thanks for all the input.
Reply 5 of 5, by rasz_pl
.. as I said ANY mpcie card is actually LPC, like $12.99 "3in1 PC Laptop Analyzer Mini PCI Mini PCI-E LPC Tester Diagnostic Post Test Card" or $12.00 "Post Card Diagnostic 3 in 1 miniPCI/PCI-E/LPC motherboard Analyzer Tester 6digit" or $3.98 "Mini 3 in1 PCI PCI-E LPC PC Laptop Analyzer Tester Diagnostic Post Test Card"
the $60 fancy one is typical scam by omission. PCIE port is non standard, its a proprietary Gigabyte solution and works only on select Gigabyte boards.
