First post, by megatron-uk
I have a hankering for building an ultra tiny 386 with one of those everything-on-a-16bit-isa-card sbc's (PC/104 is nice, but ISA is really convenient). Most come with video , but some don't, and I'd want to add audio too - that means a total of 2-3 ISA slots.
That's just the right amount that you would find on an old desktop case riser.
Is there anything (except solder points for +5, +12, -12 and ground) to stop the use of a small ISA riser as a backplane for a sbc and one or two cards?
https://www.target-earth.net
Reply 1 of 6, by weedeewee
megatron-uk wrote on 2023-01-11, 11:45:
No.
Do not ask Why !
Reply 4 of 6, by Thermalwrong
I've done this and it works, this particular SBC has super I/O and video integrated so the extra port is for the sound card.
I got an ISA single port angler, soldered another ISA connector onto the edge connector - along with the ATX connector from one of those 24pin to 20 pin ATX connectors that I sacrificed.
517.64 KiB
695.9 KiB
There's a little header for the on/off switch and the power wires were soldered onto bits of stripboard to add some strength.
I considered doing this to a 3 port ISA riser but didn't in the end because I don't like the idea of soldering onto the hard gold pins of the ISA header. Later I designed up a PCB to be a 3 port riser which simplifies the wiring significantly for SBCs:
483.85 KiB
449.12 KiB
Reply 5 of 6, by megatron-uk
Yeah - that 'shoebox' formfactor is exactly the sort of thing I am looking to achieve. Great stuff!
Did you 3d print the IO bracket holder or did you find a supplier?
Reply 6 of 6, by Thermalwrong
It's all 3d printed with some wooden dowels to give some strength to it, since I had those laying around at the time. I didn't share the designs because the PCB design has a couple of flaws, specifically in that it didn't need to be 2 boards and the ATX connector is too close to the cards.
If you're interested though, I'd be happy to share them after I get a chance to fix them. I haven't thought much about this since 2020 when I got the 5x initial PCBs made 😀
