broken graphics
First post, by marbury
Hi,
I don't know what to search for really so in case this this exact thing has been fixed already, please redirect.
General:
FIC 486 PIO2
5x86 P75 133@150MHz
miro S3 Trio64v+ PCI
The system is running smoothly but when I try to play a game or run a benchmark this happens most of the time:
https://imgur.com/YEKlf6z
It happens at least in Doom, Quake and Chris's 3d benchmark. Gods for example looks fine. Also 3D Bench looks fine. Frame rates are good (like 50-70ish FPS). The windows 3 desktop with 1024x768 looks fine. CPU and GPU are not overheating. VGA Palette snoop is on and the Video shadowing of c000-c800 (according to the miro readme) is on as well.
Has anybody ever experienced this ... and hopefully got it fixed? I will try a Trident ISA card later but I would like to use the S3.
Cheers,
Stefan
DOS Gaming: Biostar 8433UUD, AMD 5x86 P-75@150MHz, 64MB Ram, ViRGE 3D/DX, Soundblaster AWE32 8MB RAM, Dos 6.22, Win 3.11
Windows gaming: Chaintech CT-5AGM2, AMD K6-2+/570ACZ@600MHz, 384MB Ram, Voodoo 3 AGP, SoundBlaster Vibra 16, Win 98
Reply 1 of 2, by CoffeeOne
marbury wrote on 2023-01-14, 18:01:
Hi, […]
Hi,
General:
FIC 486 PIO2
5x86 P75 133@150MHz
It happens at least in Doom, Quake and this one 3D bench with the rotating cube. Gods for example looks fine. Frame rates are good (like 50ish FPS). The windows 3 desktop with 1024x768 looks fine. CPU and GPU are not overheating. VGA Palette snoop is on and the Video shadowing of c000-c800 (according to the miro readme) is on as well.
Cheers,
Stefan
Hello
You are overclocking the PCI bus to 50MHz.
Is the same issue there, when you use the default 33MHz? So CPU 3*33, or 4*33?
Edit. typo fixed
Reply 2 of 2, by marbury
CoffeeOne wrote on 2023-01-14, 18:06:
Hello You are overlocking the PCI bus to 50MHz. Is the same issue there, when you use the default 33MHz? So CPU 3*33, or 4*33? […]
Hi, […]
Hi,
General:
FIC 486 PIO2
5x86 P75 133@150MHz
Cheers,
Stefan
Hello
OMG I am such an idiot .... Forgot to set JCK and JT1 to >33MHz.... m( ... now everything is fine. Erhmahgerd. Thanks for the hint.
Cheers,
Stefan
