First post, by aaronkatrini
Hi all,
Among a recent lot of new cards purchased recently there was this 8Bit ISA card with a 40pin (IDE-like) connector and 4 dip switches on the left corner. There is a label stating this is P/N T 23687043. I tried googling it but no relevant results. Also did a search on TH99 with pics but I couldn't find anything. I kindly ask if someone can help me and give me a clue or point me to the right direction.
Also the card has a damaged capacitor that needs replacing is currently preventing me to just plug it in and try it.
Thanks in advance! 😁
https://drive.google.com/drive/folders/1dMWmZ … ?usp=share_link
Reply 1 of 6, by Horun
With a 37 pin D shell and built in 1999, am thinking it is some type industrial A/D card. No IDE card would be 8bit due to lack of the needed higher IRQs.
Reply 2 of 6, by Grzyb
Horun wrote on 2023-01-15, 16:44:
Actually, 8-bit IDE cards do exist, in both XTA and ATA variants.
However, such cards come with a BIOS, so this can't be one of them.
Doesn't look like an A/D card, either, can't see any ADC chips...
It's mostly simple 74-series TTL logic...
But there's also five SEC KA339 comparators next to the external connector, which does suggest some measurements...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 6, by weedeewee
I recall having a , I think, hitachi CDRom drive which had two 37 pin connectors. This was >30 yrs ago and at the time I didnt know what to hook it up to nor had I internet to look up what it was hooked up to and which specs it had.
Do not ask Why !
Reply 4 of 6, by Grzyb
1999 is by far too late for a proprietary CD-ROM interface.
Reply 5 of 6, by weedeewee
Grzyb wrote on 2023-01-15, 17:24:
true, true, only noticed that after I had written it 😀
Do not ask Why !
Reply 6 of 6, by aaronkatrini
Thank you all for the suggestions. I totally overlooked the facts that all the chips are from '99-ish. The board layout and the overall build quality screams early '80s.
Most likely it's something proprietary of some industrial device. Oh well in the recycling center it goes 😀
