First post, by murrayman
For years I could Google the title of this thread and find the answer fast (cause I apparently am an msconfig brat and have to remind myself every five years). Now when I do, all I get are sites with setup guides that don’t have the answer, and threads on forums from decades ago deriding the OS.
How do I go about reliably changing what boots with Windows 95, specifically OSR 2.1? I vaguely recall there being a method of doing this through the registry, but no idea if that’s accurate or not.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 1 of 7, by chinny22
Few different methods. for the registry its typically
Software\Microsoft\Windows\CurrentVersion\Run
Other options listed under the Programs when Booting section here (I seem to remember win.ini still been common in the 95 era)
http://mc-computing.com/technical/Win_95_Registry.htm
Reply 2 of 7, by elszgensa
Sysinternals' "Autoruns" covers a couple more. Probably gotta hunt down an old version though, and it's meant more for removing unwanted things than adding new ones - but at least it'll show you where to look.
Reply 3 of 7, by Vort
elszgensa wrote on 2023-01-16, 15:17:
Sysinternals' "Autoruns" covers a couple more. Probably gotta hunt down an old version though ...
Autoruns 8.51 is the last version, which works in Windows 95.
Reply 4 of 7, by Robbbert
EDIT:
Sorry , misread the question.
Reply 5 of 7, by Joseph_Joestar
I use Startup CPL under Win95.
It's a freeware tool which creates an entry under Control Panel, allowing you to see and disable every startup program.
Reply 6 of 7, by Jo22
Sysedit and msconfig? 🤷‍♂️
Reply 7 of 7, by Kahenraz
Joseph_Joestar wrote on 2024-11-28, 11:11:
This. It's excellent and much better than msconfig, even on platforms that support it.
