First post, by deksar
Hi.
I got an asterisk sign during bios post, at the line of CPU info;
(CPU1: *Intel...)
Any clue what that means? Is there anything I should worry about? CPU settings are all default (auto) values in BIOS. No overclocking/manual settings.
Thanks.
    101.7 KiB
Reply 1 of 4, by Gmlb256
Hello.
You shouldn't worry about that if the CPU works fine after POST. Depending on the motherboard BIOS, the CPU name will look slightly different during POST.
Reply 3 of 4, by snufkin
Since it shows CPU1, I wonder if the BIOS supports SMP, even if the board doesn't, and the * indicates the default CPU? I found a picture of an SMP boot on the Award Medallion BIOS here:https://www.askwoody.com/forums/users/dave3283/replies/ which shows CPU2 with a *.
    70.47 KiB
