First post, by rodney007
Hi guys,
I am trying to get Nira drag racing to work, and old dos game.
I can mount the game using the commands and the ISO image on DOSbox,
I Install game, everything seems fine however when I run the game i am prompted with "insert CD" and cannot play. Like its not detecting its mounted? but it is....
ISO is 100% mounted to D:\, as I install it from that, and game install is mounted to C, which i run the main game .exe from.
I get the same problem when I use Launchbox with iso mount locations setup correctly. Keeps asking to insert CD...
However, when I install the game using Virtual VM box with a Windows XP install its fine and I get no CD prompt (however emulation is slow and laggy).
Its almost like the game install cant see the disc is actually mounted? terribly frustrating, any help appreciated. thanks team!!!
Cheers!,
Rod
