First post, by Vic Zarratt
I don't have this, but i would likely buy one if one shows up for sale at my usual haunts.
Looking a little like a sidewinder knock-off with with dualshock style twinsticks, it uses gameport rather than USB, which is odd for a dualstick pad - can anyone shed some light on it?
    34.58 KiB
I manage a pot-pourri of video matter...
Reply 1 of 3, by kaputnik
Vic Zarratt wrote on 2023-01-26, 01:40:
Have you opened and checked if there's anything printed on the PCB? Might at least be an FCC ID if nothing else.
Reply 2 of 3, by elszgensa
> Have you opened [it]?
How would he? He wrote he doesn't have it.
Anyways. The gameport does have provisions for two joysticks, but only for four buttons - and if you look closely, both sets on this pad are labelled A through D so if I had to guess I'd say you do get two individual sticks - but not eight truly independant buttons but just some mirrored ones.
Reply 3 of 3, by Vic Zarratt
elszgensa wrote on 2023-01-27, 20:21:
Anyways. The gameport does have provisions for two joysticks, but only for four buttons - and if you look closely, both sets on this pad are labelled A through D so if I had to guess I'd say you do get two individual sticks - but not eight truly independent buttons but just some mirrored ones.
i'd say your right about the buttons, perhaps it's meant to be ambidextrous, though i don't know if there are meant to be any shoulder keys. One can also see the little face switches, maybe to switch between a few protocols as well.
