Extended Memory on PC/XT
First post, by Jo22
Hi everyone,
Here's a picture I'd like to share with you for your amusement:
MSD gets confused on my XT class machine. 😉
While XMS might be possible to simulate on an XT (the emulator PCE did it),
Extended Memory is a bit tricky with the limited number of address lines.
Reply 1 of 7, by rmay635703
What type of memory card and driver are you using?
Reply 2 of 7, by Errius
XMS on a 16-bit CPU? Don't you need 32-bit CPU for that?
Is this too much voodoo?
Reply 3 of 7, by jakethompson1
As UMB providers are a subset of XMS, providing UMBs for DOS=UMB is one legitimate use of XMS on an XT class machine.
Reply 4 of 7, by jakethompson1
Errius wrote on 2023-01-28, 19:59:
XMS itself is just a bunch of API calls for copying data to and from extended memory, abstracting away all the switches into protected mode and back. You can do this on a 286 if you have RAM above 1 MB. Part of the reason for XMS instead of just accessing the memory directly is needing to hide hardware differences with Gate A20, and for multiple programs to use extended memory at once. As I looked at the XMS spec recently, two ways programs would "allocate" extended memory before XMS existed where to either hook the interrupt vector to get the amount of extended memory and subtract out their allocation before returning to the caller (allocating top down), or alternatively, using a fake VDISK header on the block of memory (allocating bottom up) as PC-DOS VDISK was the first program to use extended memory of any form on an AT, and it bypassed HIMEM.SYS/XMS and did not need either.
Reply 5 of 7, by Errius
That's interesting, thanks. I always thought you needed a 386 for this.
Reply 6 of 7, by jakethompson1
Errius wrote on 2023-01-28, 20:55:
Probably thinking of EMM386.
Reply 7 of 7, by Grzyb
Jo22 wrote on 2023-01-28, 19:14:
What's that machine? Who made the BIOS?
My guess is the BIOS does support some function called by MSD to determine the extended memory size, but in this case that function has some other meaning, so the returned value looks nonsense...
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
