First post, by AlessandroB
PC with cache does not boot, disabling it works normally. I proceeded to uninstall the chips on the motherboard. Will the computer suffer as much in speed without L2? Or should I try to find a new one? Is there a way to test which chip is bad??
tnks
Reply 1 of 18, by pentiumspeed
Photos helps us and if you know the board model, please post them.
Cheers,
Great Northern aka Canada.
Reply 2 of 18, by douglar
If you are able to jumper the board for a reduced cache size, then you have some spare chips you can swap for testing. A small L2 cache is much better than no L2. It would help if you posted a picture or the name of your motherboard
Reply 3 of 18, by Nexxen
AlessandroB wrote on 2023-01-29, 16:18:
tnks
Faulty cache chip, I had it many times.
Unless it is not... :p
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 4 of 18, by rmay635703
Without L2 a P133 isn’t much faster than an amd 5x86-133 with full cache, especially if it is one of the early slow old Socket 4/5 Chipsets.
A very good hard drive controller and video card could make up some of the performance, especially if you can run fsb75 or 83 stable
but you will still get a lot of chugging.
Reply 5 of 18, by AlessandroB
rmay635703 wrote on 2023-01-30, 01:48:
Really soooo slow??? When i can i post some pics of the board/chip
Reply 6 of 18, by zyga64
Nope. It mainly depends on the chipset. Look for Intel 430FX benchmarks. A system without L2 cache has comparable performance to a system with Async Sram cache (those with Pipeline Burst are noticeably better).
I also remember that I had Gigabyte GA-586SG motherboard (with SIS5591 chipset) with corrupted cache memory (PB), so I used it with L2 cache disabled.
A little later I replaced both chips (cache and ram tag) and the difference was less than I expected (with L2 enabled).
L1 cache however is a whole different story....
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 8 of 18, by CoffeeOne
AlessandroB wrote on 2023-01-30, 10:00:
Sorry to ask, but ....
What is the problem in uploading pictures at Vogons? Works like a charm.
Do not use external hosting sites, please. It is annoying, there are tons of old posts, where the pictures are missing.
Reply 9 of 18, by devius
The performance hit should be less than 10% with L2 off. See this other post for more details and some examples: Pentium with no L2.
Reply 11 of 18, by AlessandroB
CoffeeOne wrote on 2023-01-30, 20:40:
Sorry to ask, but .... What is the problem in uploading pictures at Vogons? Works like a charm. Do not use external hosting site […]
The only problem is that the computer is not near me 😀 … until now. here the pics
Reply 12 of 18, by H3nrik V!
AlessandroB wrote on 2023-01-31, 07:20:
Are those 20ns cache chips? They won't run much past 50MHz FSB, I guess?
Reply 13 of 18, by AlessandroB
H3nrik V! wrote on 2023-01-31, 08:43:
I tried running the computer with a 233MMX and it works fine, bus 66, so I think the chips are working fine.
another question I wanted to ask you, in the photo you see a series of connectors on the left edge and if you read on the serigraphy you see the word "Turbo". I tried to close it with a jumper but I didn't see any effects… what do you think?
Reply 14 of 18, by Gmlb256
I do have a Gigabyte Socket 7 motherboard that has the Turbo pins which is for a toggle button that sets the FSB to 50 MHz, it is more effective when disabling the L1 cache. Yours is only for the Turbo LED according to the manual.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 15 of 18, by devius
AlessandroB wrote on 2023-01-31, 12:12:
Then why did you say it doesn't boot with cache on?
Reply 16 of 18, by douglar
Did you have the switches set for the correct cache size? looks like you have chips for a 256k cache.
Reply 17 of 18, by Windows9566
Nexxen wrote on 2023-01-29, 22:48:
tnks
unstable or faulty cache could cause lockups, program crashes, etc. or make your PC refuse to boot, was experiencing this on one of my 486 boards, i eventually got it to work with some known good ICs i have in my random ICs box, it's only 128k but it is all fine.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
