First post, by Shponglefan
Attached is an ad from Computer Gaming World (January 1993 ) advertising a sound card from MIDI Land titled the "Okey Dokey Sound Card".
Near as I can find, this is the only reference to this particular sound card. It's ad by Midi Land, Inc. Weirdly the "Okey Dokey Sound Card" is even listed with a TM symbol suggesting the name was trademarked.
Did this card ever actually exist? Was it vaporware? Does the pictured card still exist somewhere even if just in prototype form?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 9, by jmarsh
You put the sound card in, you take the sound card out, you try a new IRQ and then you throw the crap thing out...
Reply 2 of 9, by dionb
Can't comment on the release or existence in real life of the card, but the picture shows what looks like a pretty typical Sound Blaster (1) clone, with OPL2, 8051 microcontroller, non-standard DE9 joystick/midi port, volume knob, 3.5mm jack for something and USP those two RCA connectors instead of 3.5mm jack(s).
Reply 3 of 9, by Jo22
I think the same.
I also believe to see an NE558 timer IC and the required glue logic.
These ~5 TTL ICs on the left.. My Lindy gameport card has them, too.
Edit: Here it is (hi-res). Please have a look at these wonderful discreet parts!
Even the little charging caps for the 558 timer's time base are visible. ^^
Reply 5 of 9, by MobyGamer
It was real; I have one. It is nothing special; a sound blaster clone as the advert suggests. I only held onto it because of the name 😀
Reply 6 of 9, by keenmaster486
Ah yes, from a company that is definitely actually based at the California address listed in the ad!
World's foremost 486 enjoyer.
Reply 8 of 9, by leileilol
how's the low noice rate
long live PCem
Debian's fucked
Reply 9 of 9, by darry
leileilol wrote on 2025-03-21, 16:25:
I probably sounds very noice, with very low noice.
Okey Dokey ?
More seriously, it reminds me of the "Nimble" sound card, in terms of naming. I can't remember whether it was a brand or a model, but it was an ISA card.
