First post, by jamesyoung
I've got 2 multia's, a VX40 and a VX42. On both of them the floppy drive does not work, the light will flash but it will not read in NT and under SRM it thinks there is no floppy inserted. I've swapped the drive for a Sony MPF720-2 and the same error occurs. I've tried replacing the battery in them with a fully charged one and that also does not fix it. Any ideas?
