First post, by envagyok
I find a socket 4 motherboard MD54E213, and i have already a pentium 60 socket4 cpu.
I try to start it with/without ram from my 486 socket 3 , but no result.
The cpu normal heating, but speaker not beep, no picture, and the isa/pci postcard not show activities, only 00 .
Maybe must use the connector between isa and pci ports?
Thank for all helping hints.
Reply 1 of 3, by PD2JK
Too bad the BIOS chip isn't easy to swap or check.
How are your hot air soldering skills?
In my experience a potentially empty Dallas should get you at least a POST.
has all kinds of stuff
Reply 2 of 3, by envagyok
My friend is can good soldering
Reply 3 of 3, by envagyok
Discovered the problem.
3 trace was broken.
Already working.
Only one interesting thing is:
Need power on, then power off.
After that fast power on.
It can happen thanks to bad Dallas ic?
