First post, by kaputnik
Haven't managed to get the ESS Audiodrive (ES1868) in my 486 working in Windows 3.11. Tried the drivers found on Phil's Computerlab and Vogonsdrivers without success.
The computer freezes immediately when pressing the "Driver Installation" button, see attached photo. The computer has to be hard reset, it won't respond to ctrl+alt+del.
The Audiodrive works perfectly in DOS.
Noticed that the drivers I've tried only claims Windows 3.1 compatibility, not WFW 3.11 specifically. Would surprise me if the problem was related to that, but haven't had a lot of experience with Windows 3.x the last 25 years, so won't bet my right hand on it. If it is, are there any verified working drivers for Windows 3.11 at all?
Reply 1 of 13, by Rawit
Does the 1868 have the MPU port enabled under DOS? If not, it might be Windows trying to activate it and running into a conflict. Check the ouput of ESSCFG.
YouTube
Reply 2 of 13, by kaputnik
Rawit wrote on 2023-02-14, 13:26:
Normally starting Windows from a DOS boot menu, not initializing the 1868 at all before launching Windows. Tried initializing it with the MPU port disabled as you suggest before launching Windows, in case the card not being initialized might cause problems, but the computer still freezes at the same point in the driver setup.
Any other ideas? 😀
Reply 4 of 13, by kaputnik
davidrg wrote on 2023-02-14, 22:33:
Without knowing where the drivers on vogonsdrivers or phils computer lab came from, it might be worth trying the drivers direct(ish) from the source: https://www.zx.net.nz/mirror/www.esstech.com/ … pp/drivers.html
The 1868 win3.11 driver seems to be identical to the one on Phils Computer Lab. Tried installing it just for the hell of it, but as expected the computer froze the same way as before. Thanks anyways though 😀
Reply 5 of 13, by Rawit
I think the first action the installer does is copying files instead of config. Might be disk io related?
YouTube
Reply 6 of 13, by kaputnik
Rawit wrote on 2023-02-15, 10:24:
Hm, well, haven't seen any other signs of disk I/O problems at all, everything works perfectly in that department. If anything, this computer is remarkably stable and well working to be a 486. Tried launching the installer from a floppy instead, and the installer freezes just as before. For obvious reasons I couldn't try with the IDE controller disabled though, writing to the OS install location of course has to happen no matter of what source I use.
Unfortunately there's no oemsetup.inf, so there's no way I know of at least to install the driver from the control panel etc, instead of the setup program.
Reply 7 of 13, by Rawit
Does your mainboard support PnP? I don't have an 1868 around unfortunately. It might try to check available resources and runs into a conflict, not sure. Hopefully somebody with an 1868 can chime in.
YouTube
Reply 8 of 13, by kaputnik
Rawit wrote on 2023-02-16, 08:54:
It doesn't seem to. Can't find any ISA PnP related settings in the BIOS setup, and there's the "PCI configuration setup" option, that usually is called "PCI/PnP configuration setup" on PnP enabled boards.
The "mainboard" is an SBC, IEI SSC-486H Ver C. The BIOS is Award 4.51G.
Launched CheckIt from Windows, see attached screenshot. The IRQs and DMA channels commonly used by default by sound cards are free if CheckIt can be trusted, and there's also plenty of other to choose from. I doubt it's some kind of resource conflict.
Reply 9 of 13, by Rawit
It might try to set the MPU to IRQ 2/9.
YouTube
Reply 10 of 13, by kaputnik
Rawit wrote on 2023-02-19, 21:23:
Well, as mentioned I tried disabling the MPU port with esscfg before starting Windows and trying to install the driver. Did not help.
Reply 11 of 13, by anetanel
I just had the same issue, and I was about to ask if you found a solution, when I managed to make it work 😀
I believe the issue was that I had several unformatted logical partitions on the drive (sd card). Once I removed them, and had only 2 formatted partitions, the installation worked.
I also started windows with /n flag to disable networking, as I thought it may have something to do. I don't think that was the issue though, but worth a try too.
Reply 12 of 13, by JDZero
Sorry for resurrecting the thread in 2026: I've been messing around with Networking on a 486 using WFW, and I've come across some interesting behavior. When installing base-line Win3.1 (non-WFW), and then going in and installing the ESS drivers (namely the ones that PHIL / ESS posted), the drivers installed fine. Now, I'm still fiddling with this since I'm trying to get this machine onto the network to use TelNet functions, but from what I've seen so far there's some sort of conflict with the networking soft that causes the ESS installer to freeze on WFW, even under a fresh install with no other settings changed at first start-up.
I think if others go about testing this route (e.g. install base-line Win3.1, or _possibly_ WFW sans any networking drivers), they might get the same results. Either way, I hope this helps anyone else!
Reply 13 of 13, by akimmet
I have been able to get the ESS drivers to not hang on WFW 3.11 startup, by abandoning the ESS DOS driver. Initializing the sound card with UNISOUND instead seems to work somehow.
