First post, by Almoststew1990
I'm looking to get a S370 board but the two that look in good condition and are not too pricey have VIA Apollo or VIA 694X chipsets. The latter board takes 66 to 133MHz FSB CPUs but only supports Celerons. Is this actually correct, how is it "locked down" like this?
Reply 1 of 1, by Repo Man11
I had one of these and it worked with a 600 MHz Coppermine Celeron as is (though it wasn't correctly identified on POST). With a Lin Lin adapter I was able to run a 1200 MHz Tualatin Celeron.
http://www.motherboard.cz/mb/epox/EP-V370B.htm
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
