First post, by cookertron
Hi John,
I want to populate my dual slot 1 GA- BX6DX with a couple of high speed CPUs. So far I've got 2x 450hmz but in the board's manual it says there's PII 500 & and 550. Wikipedia says that the PII only goes up to 450 so what gives?
Thanks for the info (in advance).
Anthony
106.49 KiB
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 1 of 8, by MadMac_5
That's very likely a typo and they meant to put Pentium III there. Quality control for motherboard manuals was pretty relaxed at that time, and there were more than a few times that I found outright errors. Never mind the fact that translations were often... less than perfect in that period.
Reply 2 of 8, by BitWrangler
Like the Intel 486 DX40, the Intel 486 DX4-120, they were CPUs that motherboard manufacturers guessed at, but Intel never released.
Reply 3 of 8, by Standard Def Steve
For a while, Katmai was expected to be yet another Pentium II. Your manual was likely printed in late '98 or very early '99, when manufacturers were aware of Katmai's existence but before Intel decided to brand it Pentium III.
Reply 4 of 8, by cookertron
MadMac_5 wrote on 2023-02-14, 16:11:
I take it the manual's refering to the Katmai PIII 500mhz and 550hmz? It doesn't mention the 600mhz Katmai variant was that not supported?
Unfortunately for me I have the BX6DS v1.7 which doesn't support Coppermine otherwise I'd be cranking the mhz up to 1000!
Standard Def Steve wrote on 2023-02-14, 16:23:
That's very plausible, thanks for the info.
Reply 5 of 8, by JayAlien
As mentioned, the Pentium II was expected to be longer lived, but after only about a year on the market Intel rebranded it to Pentium III.
Here is a contemporary article, postulating that the third gen Pentium IIs would increase up to 600MHz
https://www.anandtech.com/show/55
These projected Deschutes likely were given a tweak and released as Katmai.
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 6 of 8, by cookertron
JayAlien wrote on 2023-02-14, 20:23:
As mentioned, the Pentium II was expected to be longer lived, but after only about a year on the market Intel rebranded it to Pe […]
Thanks for the info, it'll be good to know what I'm talking about eventually 🙂
Reply 7 of 8, by rmay635703
BitWrangler wrote on 2023-02-14, 16:15:
In some cases they were on the early “future looking” NDA protected CPU timelines
DX3-75 and DX4-90 were hinted at circa 1991.
Pentium 80mhz was also on the timeline during the socket 4 release (some boards that hit retail would have even supported it).
Intel instead skipped straight to Pentium 90mhz from 60mhz
And 486-100mhz from 66mhz
If AMD had not been pressuring Intel it’s possible the PII-500 would have released instead of the slightly improved PIII-500
Oddly early 500mhz engineering samples were sometimes improperly labeled
https://www.engineering-sample.com/gallery/In … ium%20II%20500/
Reply 8 of 8, by Big Pink
It really should have been called the Pentium II SSE, as per the Pentium MMX. And then the Pentium 4... oh never mind. This is what happens when marketing runs the show.
I thought IBM was born with the world
